DecimalSeparator 属性 (ActiveX)
指定要用作十进制尺寸和公差值中的小数分隔符的字符。 支持的平台:仅限 Windows 签名VBA: object.DecimalSeparator 属性值只读:不 类型:字符串 在十进制值中用作分隔符的单个字符。 言论此属性的初始值为“.”。 任何字符都将被接受为此属性的有效值。 仅当该属性设置为 时,才会使用此属性。UnitsFormatacDimDecimal 注意:此属性将覆盖给定维度的 DIMDSEP 系统变量的值。
例子VBA: Sub Example_DecimalSeparator()
' This example creates a Dim3PointAngular object in model space
' and allows the user to change the decimal separator appearance
' using the DecimalSeparator property
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
Dim oldSeparator As String, newSeparator As String
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Set precision so that degrees are visible
DimPointAngularObj.TextPrecision = acDimPrecisionFour
' Read and display current decimal separator
MsgBox "The decimal separator for this object is currently set to: [" & DimPointAngularObj.DecimalSeparator & "]"
' Alter the decimal separator property for this object
oldSeparator = DimPointAngularObj.DecimalSeparator
newSeparator = InputBox("Enter a new decimal separator", "Change Decimal Separator", oldSeparator)
If newSeparator = "" Then
Exit Sub
Else
' Set new decimal separator, making sure to use only one character
DimPointAngularObj.DecimalSeparator = Left(newSeparator, 1)
End If
MsgBox "The decimal separator for this object is now set to: [" & DimPointAngularObj.DecimalSeparator & "]"
可视化 LISP: (vl-load-com)
(defun c:Example_DecimalSeparator()
;; This example creates a Dim3PointAngular object in model space
;; and allows the user to change the decimal separator appearance
;; using the DecimalSeparator property
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
;; Set precision so that degrees are visible
(vla-put-TextPrecision DimPointAngularObj acDimPrecisionFour)
(vla-ZoomAll acadObj)
;; Read and display current decimal separator
(alert (strcat "The decimal separator for this object is currently set to: [" (vla-get-DecimalSeparator DimPointAngularObj) "]"))
;; Alter the decimal separator property for this object
(setq oldSeparator (vla-get-DecimalSeparator DimPointAngularObj))
(setq newSeparator (getstring "\nEnter a new decimal separator: "))
(if (/= newSeparator "")
;; Set new decimal separator, making sure to use only one character
(vla-put-DecimalSeparator DimPointAngularObj newSeparator)
(alert (strcat "The decimal separator for this object is now set to: [" (vla-get-DecimalSeparator DimPointAngularObj) "]"))
GMT+8, 2026-10-28 08:16
