Database 属性 (ActiveX)
获取对象所属的数据库。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Database()
' This example references the Database object obtained from model space.
' Information from the Database object is then displayed
Dim Database As AcadDatabase
' Attach to Database object
Set Database = ThisDrawing.ModelSpace.Database
MsgBox "We now have access to the properties and methods of the Database object!"
' Retrieve the number of Blocks in this database
MsgBox "The number of Blocks in this database is: " & Database.Blocks.Count
' Release object
Set Database = Nothing
MsgBox "The Database object has been released!"
可视化 LISP: (vl-load-com)
(defun c:Example_Database()
;; This example references the Database object obtained from model space.
;; Information from the Database object is then displayed
;; Attach to Database object
(setq database (vla-get-Database (vla-get-ModelSpace doc)))
(alert "We now have access to the properties and methods of the Database object!")
;; Retrieve the number of Blocks in this database
(alert (strcat "The number of Blocks in this database is: " (itoa (vla-get-Count (vla-get-Blocks database)))))
;; Release object
(vlax-release-object database)
(alert "The Database object has been released!")
GMT+8, 2026-10-28 04:49
