CursorSize 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 1014| 评论: 0|原作者: admin|来自: AutoCAD
将十字准线大小指定为屏幕大小的百分比。
object.CursorSize
类型:首选项显示
此属性应用于的对象。
只读:不
类型:整数
从 1 到 100 的正整数,表示十字准线大小占总屏幕面积的百分比。
此属性的默认值为 5%。
允许的范围是总屏幕的 1% 到 100%。在 100% 时,十字准线的末端不可见。如果尺寸减小到 99% 或更低,则十字准线的尺寸有限,并且当移动到绘图区域的边缘时,十字准线的末端是可见的。
注意:此属性的值存储在 CURSORSIZE 系统变量中。
Sub Example_CursorSize()
    ' CursorSize. It then changes the value, and finally
    Dim currCursorSize As Integer
    Dim newCursorSize As Integer
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current CursorSize value
    currCursorSize = preferences.DISPLAY.CursorSize
    MsgBox "The current value for CursorSize is " & currCursorSize, vbInformation, "CursorSize Example"
    ' Change the value for CursorSize
    newCursorSize = 10
    preferences.DISPLAY.CursorSize = newCursorSize
    MsgBox "The new value for CursorSize is " & newCursorSize, vbInformation, "CursorSize Example"
    ' Reset CursorSize to its original value
    preferences.DISPLAY.CursorSize = currCursorSize
    MsgBox "The CursorSize value is reset to " & currCursorSize, vbInformation, "CursorSize Example"
(defun c:Example_CursorSize()
    ;; CursorSize. It then changes the value, and finally
    ;; Retrieve the current CursorSize value
    (setq currCursorSize (vla-get-CursorSize (vla-get-Display preferences)))
    (alert (strcat "The current value for CursorSize is " (itoa currCursorSize)))
    ;; Change the value for CursorSize
    (setq newCursorSize 10)
    (vla-put-CursorSize (vla-get-Display preferences) newCursorSize)
    (alert (strcat "The new value for CursorSize is " (itoa newCursorSize)))
    ;; Reset CursorSize to its original value
    (vla-put-CursorSize (vla-get-Display preferences) currCursorSize)
    (alert (strcat "The CursorSize value is reset to " (itoa currCursorSize)))
GMT+8, 2026-10-28 07:53
