CreateBackup 属性 (ActiveX)
指定备份文件的使用。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 此属性通过创建备份文件 (.bak) 来提高增量保存的速度。操作系统复制文件数据以为大型图形创建备份文件,这需要大部分增量保存时间。 谨慎:如果出现问题(例如在保存过程中断电),图形数据可能会丢失。
注意:此属性的值存储在 ISAVEBAK 系统变量中。
例子VBA: Sub Example_CreateBackup()
' CreateBackup. It then changes the value, and finally
Dim currCreateBackup As Boolean
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current CreateBackup value
currCreateBackup = preferences.OpenSave.CreateBackup
MsgBox "The current value for CreateBackup is " & preferences.OpenSave.CreateBackup, vbInformation, "CreateBackup Example"
' Change the value for CreateBackup
preferences.OpenSave.CreateBackup = Not (currCreateBackup)
MsgBox "The new value for CreateBackup is " & preferences.OpenSave.CreateBackup, vbInformation, "CreateBackup Example"
' Reset CreateBackup to its original value
preferences.OpenSave.CreateBackup = currCreateBackup
MsgBox "The CreateBackup value is reset to " & preferences.OpenSave.CreateBackup, vbInformation, "CreateBackup Example"
可视化 LISP: (vl-load-com)
(defun c:Example_CreateBackup()
;; CreateBackup. It then changes the value, and finally
;; Retrieve the current CreateBackup value
(setq currCreateBackup (vla-get-CreateBackup (vla-get-OpenSave preferences)))
(alert (strcat "The current value for CreateBackup is " (if (= currCreateBackup :vlax-true) "True" "False")))
;; Change the value for CreateBackup
(setq newCreateBackup (if (= currCreateBackup :vlax-true) :vlax-false :vlax-true))
(vla-put-CreateBackup (vla-get-OpenSave preferences) newCreateBackup)
(alert (strcat "The new value for CreateBackup is " (if (= newCreateBackup :vlax-true) "True" "False")))
;; Reset CreateBackup to its original value
(vla-put-CreateBackup (vla-get-OpenSave preferences) currCreateBackup)
(alert (strcat "The CreateBackup value is reset to " (if (= currCreateBackup :vlax-true) "True" "False")))
GMT+8, 2026-10-28 00:10
