Count 属性 (ActiveX)
获取对象中的项数。 支持的平台:仅限 Windows 属性值只读:是的 类型:整数 对象中的项数。 言论没有其他评论。 例子VBA: Sub Example_Count()
' Use count to retrieve the number of objects in a collection
' You might use this value in a loop structure to iterate through the collection
MsgBox "There are " & ThisDrawing.Layers.Count & " layer(s) in the drawing."
MsgBox "There are " & ThisDrawing.ModelSpace.Count & " object(s) in ModelSpace."
Dim objCount As Integer
Dim I As Integer
objCount = ThisDrawing.ModelSpace.Count
Dim mspaceObj As AcadObject
For I = 0 To objCount - 1
Set mspaceObj = ThisDrawing.modelSpace.Item(I)
MsgBox "The objects in ModelSpace include: " & mspaceObj.ObjectName, vbInformation, "Count Example"
Next
可视化 LISP: (vl-load-com)
(defun c:Example_Count()
;; Use count to retrieve the number of objects in a collection
;; You might use this value in a loop structure to iterate through the collection
(alert (strcat "There are " (itoa (vla-get-Count (vla-get-Layers doc))) " layer(s) in the drawing."))
(alert (strcat "There are " (itoa (vla-get-Count (vla-get-ModelSpace doc))) " object(s) in ModelSpace."))
(setq I 0
objCount (vla-get-Count (vla-get-ModelSpace doc)))
(while (>= (- objCount 1) I)
(setq mspaceObj (vla-Item (vla-get-ModelSpace doc) I)
I (1+ I))
(alert (strcat "The objects in ModelSpace include: " (vla-get-ObjectName mspaceObj)))
GMT+8, 2026-10-27 04:17
