ControlPoints 属性 (ActiveX)
指定样条的控制点。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双打数组) 样条曲线的 3D WCS 控制点数组。 言论您可以使用属性了解样条曲线具有多少个控制点。NumberOfControlPoints 例子VBA: Sub Example_ControlPoints()
' This example creates a Spline object in model space, reads the control points
' of the Spline and then modifies the control points of the Spline.
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
Dim UserMessage As String
Dim ControlPoints As Variant
Dim iCount As Long, iPoint As Integer
' Define the Spline object
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
' Create new Spline object
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
' Display control points for this Spline
GoSub DISPLAYPOINTS
' Modify control points for this Spline
ControlPoints(0) = 3
splineObj.ControlPoints = ControlPoints
' Display new control points for this Spline
GoSub DISPLAYPOINTS
Exit Sub
DISPLAYPOINTS:
ControlPoints = splineObj.ControlPoints
' Display in groups of three
UserMessage = ""
iPoint = 0
For iCount = 0 To UBound(ControlPoints) Step 3
iPoint = iPoint + 1
UserMessage = UserMessage & iPoint & ")" & vbTab
UserMessage = UserMessage & ControlPoints(iCount)
UserMessage = UserMessage & ", " & ControlPoints(iCount + 1)
UserMessage = UserMessage & ", " & ControlPoints(iCount + 2)
UserMessage = UserMessage & vbCrLf
Next
MsgBox "The " & splineObj.NumberOfControlPoints & " Spline control points are: " & vbCrLf & vbCrLf & UserMessage
Return
可视化 LISP: (vl-load-com)
(defun c:Example_ControlPoints()
;; This example creates a Spline object in model space, reads the control points
;; of the Spline and then modifies the control points of the Spline.
;; Define the Spline object
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(0 0 0
5 5 0
10 0 0
;; Create new Spline object
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Display control points for this Spline
(setq ControlPoints (vlax-variant-value (vla-get-ControlPoints splineObj)))
;; Display in groups of three
(setq UserMessage ""
iPoint 0
iCount 0)
(while (>= (vlax-safearray-get-u-bound ControlPoints 1) iCount)
(setq iPoint (1+ iPoint))
(setq UserMessage (strcat UserMessage (itoa iPoint) ") "
(rtos (nth iCount (vlax-safearray->list ControlPoints)) 2) ", "
(rtos (nth (+ iCount 1) (vlax-safearray->list ControlPoints)) 2) ", "
(rtos (nth (+ iCount 2) (vlax-safearray->list ControlPoints)) 2) "\n"
(setq iCount (+ iCount 3))
(alert (strcat "The " (itoa (vla-get-NumberOfControlPoints splineObj)) " Spline control points are: " "\n\n" UserMessage))
;; Modify control points for this Spline
(setq newFitPoint (vlax-3d-point 8 2 0))
(vla-AddFitPoint splineObj 3 newFitPoint)
;; Display new control points for this Spline
iPoint 0
iCount 0)
GMT+8, 2026-10-27 05:24
