ContourLinesPerSurface 属性 (ActiveX)
指定对象上每个曲面的等值线(等值线)数。 支持的平台:仅限 Windows 属性值只读:不 类型:整数 有效范围为 0 到 2047。 言论此属性的初始值为 4。 ![]() ContourLinesPerSurface 设置为 4 的圆环 ![]() ContourLinesPerSurface 设置为 20 的圆环 注意:此属性的值存储在 ISOLINES 系统变量中。
例子VBA: Sub Example_ContourLinesPerSurface()
' ContourLinesPerSurface. It then changes the value, and finally
Dim currContourLinesPerSurface As Integer
Dim newContourLinesPerSurface As Integer
' Retrieve the current ContourLinesPerSurface value
currContourLinesPerSurface = ThisDrawing.preferences.ContourLinesPerSurface
MsgBox "The current value for ContourLinesPerSurface is " & currContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
' Change the value for ContourLinesPerSurface
newContourLinesPerSurface = 2001
ThisDrawing.preferences.ContourLinesPerSurface = newContourLinesPerSurface
MsgBox "The new value for ContourLinesPerSurface is " & newContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
' Reset ContourLinesPerSurface to its original value
ThisDrawing.preferences.ContourLinesPerSurface = currContourLinesPerSurface
MsgBox "The ContourLinesPerSurface value is reset to " & currContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ContourLinesPerSurface()
;; ContourLinesPerSurface. It then changes the value, and finally
(setq preferences (vla-get-Preferences doc))
;; Retrieve the current ContourLinesPerSurface value
(setq currContourLinesPerSurface (vla-get-ContourLinesPerSurface preferences))
(alert (strcat "The current value for ContourLinesPerSurface is " (itoa currContourLinesPerSurface)))
;; Change the value for ContourLinesPerSurface
(setq newContourLinesPerSurface 2001)
(vla-put-ContourLinesPerSurface preferences newContourLinesPerSurface)
(alert (strcat "The new value for ContourLinesPerSurface is " (itoa newContourLinesPerSurface)))
;; Reset ContourLinesPerSurface to its original value
(vla-put-ContourLinesPerSurface preferences currContourLinesPerSurface)
(alert (strcat "The ContourLinesPerSurface value is reset to " (itoa currContourLinesPerSurface)))
GMT+8, 2026-10-26 23:55
