Constant 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 745| 评论: 0|原作者: admin|来自: AutoCAD
指定属性或属性引用是否为常量。
object.Constant
类型:Attribute、AttributeReference
此属性应用于的对象。
只读:不,对象;是的,对象AttributeAttributeReference
类型:布尔
  • True:该属性是常量属性。
  • False:该属性不是常量属性。
常量属性是在每次出现时都保持相同值的属性。AutoCAD 不会提示输入常量属性值。属性只能作为四种可选模式之一存在:常量、预设、不可见或验证。
注意:AFLAGS 系统变量存储当前模式设置。可以使用该属性查询当前模式。Mode
Sub Example_Constant()
    ' This example creates an attribute definition in model space.
    ' It then queries the attribute to see if it is a constant attribute.
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim tag As String
    Dim value As String
    ' Define the attribute definition
    height = 1#
    mode = acAttributeModeVerify
    prompt = "New Prompt"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
    tag = "New_Tag"
    value = "New Value"
    ' Create the attribute definition object in model space
    Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ZoomAll
    ' Query the attribute
    GoSub QUERYSTATUS
    ' Change the attribute
    attributeObj.constant = Not attributeObj.constant
    GoSub QUERYSTATUS
    Exit Sub
QUERYSTATUS:
    If attributeObj.constant Then
        MsgBox "The attribute is a constant attribute."
    Else
        MsgBox "The attribute is not a constant attribute."
    End If
    Return
(defun c:Example_Constant()
    ;; This example creates an attribute definition in model space.
    ;; It then queries the attribute to see if it is a constant attribute.
    ;; Define the attribute definition
    (setq insertionPoint (vlax-3d-point 5 5 0)
          attHeight 1
          attMode acAttributeModeVerify
          attPrompt "New Prompt"
          attTag "New_Tag"
          attValue "New Value")
    ;; Create the attribute definition object in model space
    (setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
    (vla-ZoomAll acadObj)
    ;; Query the attribute
    (if (= (vla-get-Constant attributeObj) :vlax-true)
        (alert "The attribute is a constant attribute.")
        (alert "The attribute is not a constant attribute.")
    ;; Change the attribute
    (vla-put-Constant attributeObj (if (= (vla-get-Constant attributeObj) :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-10-27 05:47
