ConfigName 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 811| 评论: 0|原作者: admin|来自: AutoCAD
指定绘图仪配置名称。
object.ConfigName
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:字符串
布局或打印配置要使用的 PC3 文件或打印设备的名称。
此属性不采用完全限定的路径,而只采用配置文件的文件名。使用该属性指定打印机配置文件的路径。PrinterConfigPath
在尝试更改属性之前,请使用该方法。RefreshPlotDeviceInfoConfigName
不要为属性赋值“None”。尝试这样做会导致意外行为。ConfigName
Sub Example_ConfigName()
    ' This example will add a new plot configuration to the current drawing.
    ' It will then list the plotter configuration file name for each Layout
    ' in the current drawing, change the configuration for Layout1 to "DWF Classic.pc3"
    ' and re-display the configuration information for the drawing.
    ' * Note: File names may differ on your system, so be prepared to change
    ' the configuration file name used in the example to a file that exists
    ' on your system.
    Dim Layouts As AcadLayouts, Layout As ACADLayout
    Dim msg As String
    Dim ACADPref As AcadPreferencesFiles
    Dim originalValue As Variant
    ' Get the files preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Files
    originalValue = ACADPref.PrinterConfigPath
    ' Get layouts collection from document object
    Set Layouts = ThisDrawing.Layouts
    ' Display current plotter configuration information
    GoSub DISPLAY_CONFIG
    ' Change plotter configuration file for "Layout1"
    Layouts("Layout1").ConfigName = "DWF6 ePlot.pc3"
    ' Display new plotter configuration information
    Exit Sub
DISPLAY_CONFIG:
    msg = vbCrLf & vbCrLf   ' Start with a space
    ' Format and display current directory for configuration files
    msg = msg & vbTab & "Directories that will be scanned for the plotter configuration files are: " _
                & vbCrLf & vbTab & vbTab & originalValue & vbCrLf & vbCrLf
    ' Get the plotter configuration name of every layout in this drawing
    For Each Layout In Layouts
        ' Format for display
        msg = msg & vbTab & Layout.name & " is using configuration: " & Layout.ConfigName & vbCrLf
    Next
    ' Display paper units information
    MsgBox "The plotter configuration information used in the current drawing is listed below." & msg
    Return
(defun c:Example_ConfigName()
    ;; This example will add a new plot configuration to the current drawing.
    ;; It will then list the plotter configuration file name for each Layout
    ;; in the current drawing, change the configuration for Layout1 to "DWF Classic.pc3"
    ;; and re-display the configuration information for the drawing.
    ;; * Note: File names may differ on your system, so be prepared to change
    ;; the configuration file name used in the example to a file that exists
    ;; on your system.
    ;; Get the files preferences object
    (setq ACADPref (vla-get-Files (vla-get-Preferences acadObj)))
    (setq originalValue (vla-get-PrinterConfigPath ACADPref))
    ;; Get layouts collection from document object
    (setq Layouts (vla-get-Layouts doc))
    ;; Format and display current directory for configuration files
    (setq msg "")
    (setq msg (strcat msg "Directories that will be scanned for the plotter configuration files are: \n"
                          originalValue "\n"))
    ;; Get the plotter configuration name of every layout in this drawing
    (vlax-for Layout Layouts
        (setq msg (strcat msg "\n" (vla-get-Name Layout) " is using configuration: " (vla-get-ConfigName Layout)))
    ;; Display paper units information
    (alert (strcat "The plotter configuration information used in the current drawing is listed below.\n\n" msg))
    ;; Change plotter configuration file for "Layout1"
    (vla-put-ConfigName (vla-Item Layouts "Layout1") "DWF6 ePlot.pc3")
    ;; Display new plotter configuration information
    (setq msg "")
GMT+8, 2026-10-27 03:47
