CommandDisplayName 属性 (ActiveX)
指定工具栏上按钮的显示命令名称。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 命令名称的字符串。 言论没有其他评论。 例子VBA: Sub Example_CommandDisplayName()
Dim currMenuGroup As AcadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
Dim newToolBar As AcadToolbar
Set newToolBar = currMenuGroup.Toolbars.Add("TestNewToolbar")
' Add a button to the new toolbar.
Dim newButton1 As IAcadToolbarItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newButton1 = newToolBar.AddToolbarButton("", "NewButton1", "Open a file.", openMacro)
' Display the toolbar
newToolBar.Visible = True
newButton1.CommandDisplayName = "Open a File"
' Read the current value of the Help string
MsgBox "The current CommandDisplayName for the toolbar button is: " & newButton1.CommandDisplayName
' Change the value of the CommandDisplayName
newButton1.CommandDisplayName = "Open File"
' Read the new value of the CommandDisplayName
MsgBox "The new CommandDisplayName for the toolbar button is: " & newButton1.CommandDisplayName
可视化 LISP: (vl-load-com)
(defun c:Example_CommandDisplayName()
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new toolbar
(setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestToolbar"))
;; Assign the macro string the VB equivalent of "ESC ESC _open "
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newButton1 (vla-AddToolbarButton newToolBar "" "NewButton1" "Open a file." openMacro))
;; Display the toolbar
(vla-put-Visible newToolBar :vlax-true)
(vla-put-CommandDisplayName newButton1 "Open a File")
;; Read the current value of the Help string
(alert (strcat "The current CommandDisplayName for the toolbar button is: " (vla-get-CommandDisplayName newButton1)))
;; Change the value of the CommandDisplayName
(vla-put-CommandDisplayName newButton1 "Open File")
;; Read the new value of the CommandDisplayName
(alert (strcat "The new CommandDisplayName for the toolbar button is: " (vla-get-CommandDisplayName newButton1)))
GMT+8, 2026-10-28 06:06
