ColorMethod 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 684| 评论: 0|原作者: admin|来自: AutoCAD
指定颜色方法。
object.ColorMethod
类型:AcCmColor
此属性应用于的对象。
只读:不
类型:枚举acColorMethod
默认颜色方法为 。要直接确定颜色的设置方式,请使用此处列出的常量:acColorMethodByLayer
  • acColorMethodByACI
  • acColorMethodByBlock
  • acColorMethodByLayer
  • acColorMethodByRGB
  • acColorMethodForeground
Sub Example_ColorMethod()
    ' This example shows how to change the
    ' ColorMethod property
    Dim col As AcadAcCmColor
    Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(CStr(AcadApplication.Version), 2))
    col.ColorMethod = AutoCAD.acColorMethodForeground
    ' Circle number one
    Dim cir1 As AcadCircle
    Dim pt(0 To 2) As Double
    Set cir1 = ThisDrawing.modelSpace.AddCircle(pt, 2)
    cir1.TrueColor = col
    ZoomAll
    Dim retCol As AcadAcCmColor
    Set retCol = cir1.TrueColor
    ' Message box with method and index
    Dim MethodText As String
    MethodText = col.ColorMethod
    MsgBox "ColorMethod=" & MethodText & vbCrLf & "Index=" & col.ColorIndex
    ' Circle number two
    Dim cir2 As AcadCircle
    Set cir2 = ThisDrawing.modelSpace.AddCircle(pt, 6)
    ZoomAll
    col.ColorMethod = AutoCAD.acColorMethodByBlock
    ' Circle number three
    Dim cir3 As AcadCircle
    Set cir3 = ThisDrawing.modelSpace.AddCircle(pt, 10)
    ZoomAll
    Dim layColor As AcadAcCmColor
    Set layColor = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." + Left(CStr(AcadApplication.Version), 2))
    layColor.SetRGB 122, 199, 25
    ThisDrawing.ActiveLayer.TrueColor = layColor
    col.ColorMethod = AutoCAD.acColorMethodByLayer
    Set retCol = cir3.TrueColor
(defun c:Example_ColorMethod()
    ;; This example shows how to change the
    ;; ColorMethod property
    (setq col (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-put-ColorMethod col acColorMethodForeground)
    ;; Circle number one
    (setq pt (vlax-3d-point 0 0 0))
    (setq cir1 (vla-AddCircle modelSpace pt 2))
    (vla-put-TrueColor cir1 col)
    (vla-ZoomAll acadObj)
    (vla-Regen doc :vlax-true)
    (setq retCol (vla-get-TrueColor cir1))
    ;; Message box with method and index
    (setq MethodText (vla-get-ColorMethod col))
    (alert (strcat "ColorMethod=" (itoa MethodText) "\nIndex=" (itoa (vla-get-ColorIndex col))))
    ;; Circle number two
    (setq cir2 (vla-AddCircle modelSpace pt 6))
    (vla-put-ColorMethod col acColorMethodByBlock)
    ;; Circle number three
    (setq cir3 (vla-AddCircle modelSpace pt 10))
    (setq layColor (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB layColor 122 199 25)
    (vla-put-TrueColor (vla-get-ActiveLayer doc) layColor)
    (vla-put-ColorMethod col acColorMethodByLayer)
    (setq retCol (vla-get-TrueColor cir3))
    ;;Message box with method and index
    (vlax-release-object col)
GMT+8, 2026-10-27 04:56
