Circumference 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 1000| 评论: 0|原作者: admin|来自: AutoCAD
指定圆的周长。
object.Circumference
类型:圆形
此属性应用于的对象。
只读:不
类型:双
圆的周长。
Sub Example_Circumference()
    ' This example creates a Circle object in model space and
    ' returns the circumference of the Circle
    Dim circleObj As AcadCircle
    Dim radius As Double
    ' Define the new Circle object
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    MsgBox "The circumference of the new Circle is: " & circleObj.Circumference
(defun c:Example_Circumference()
    ;; This example creates a Circle object in model space and
    ;; returns the circumference of the Circle
    ;; Define the new Circle object
    (setq centerPoint (vlax-3d-point 5 5 0)
          radius 5)
    ;; Create the Circle object in model space
    (setq circleObj (vla-AddCircle modelSpace centerPoint radius))
    (vla-ZoomAll acadObj)
    (alert (strcat "The circumference of the new Circle is: " (rtos (vla-get-Circumference circleObj) 2)))
GMT+8, 2026-10-27 05:16
