CenterType 属性 (ActiveX)
指定径向尺寸和直径尺寸的中心标记类型。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acDimCenterType
言论仅当将尺寸线放置在圆或圆弧之外时,中心标记才可见。
注意:此属性将覆盖给定维度的 DIMCEN 系统变量的值。
例子VBA: Sub Example_CenterType()
' This example creates a diametric dimension in model space.
' It then changes the type of center for the dimension.
Dim dimObj As AcadDimDiametric
Dim chordPoint(0 To 2) As Double
Dim farChordPoint(0 To 2) As Double
Dim leaderLength As Double
' Define the dimension
chordPoint(0) = 5#: chordPoint(1) = 3#: chordPoint(2) = 0#
farChordPoint(0) = 5#: farChordPoint(1) = 5#: farChordPoint(2) = 0#
leaderLength = 1#
' Create the diametric dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimDiametric(chordPoint, farChordPoint, leaderLength)
ZoomAll
' Set the center to be none
dimObj.CenterType = acCenterNone
dimObj.Update
MsgBox "The dimension center type is set to none."
' Change the center type to center mark
dimObj.CenterType = acCenterMark
dimObj.Update
MsgBox "The dimension center type is set to center mark."
' Change the center type to center line
dimObj.CenterType = acCenterLine
dimObj.Update
MsgBox "The dimension center type is set to center line."
可视化 LISP: (vl-load-com)
(defun c:Example_CenterType()
;; This example creates a diametric dimension in model space.
;; It then changes the type of center for the dimension.
;; Define the dimension
(setq chordPoint (vlax-3d-point 5 3 0)
farChordPoint (vlax-3d-point 5 5 0)
leaderLength 1)
;; Create the diametric dimension in model space
(setq dimObj (vla-AddDimDiametric modelSpace chordPoint farChordPoint leaderLength))
(vla-ZoomAll acadObj)
;; Set the center to be none
(vla-put-CenterType dimObj acCenterNone)
(vla-Update dimObj)
(alert "The dimension center type is set to none.")
;; Change the center type to center mark
(vla-put-CenterType dimObj acCenterMark)
(vla-Update dimObj)
(alert "The dimension center type is set to center mark.")
;; Change the center type to center line
(vla-put-CenterType dimObj acCenterLine)
(vla-Update dimObj)
(alert "The dimension center type is set to center line.")
GMT+8, 2026-10-27 05:54
