CenterPlot 属性 (ActiveX)
指定绘图在介质上的居中位置。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论在重新生成图形之前,对此属性的更改将不可见。使用该方法重新生成图形。Regen 不能在属性设置为 的布局对象上将此属性设置为 。TruePlotTypeacLayout 例子VBA: Sub Example_CenterPlot()
' This example will access the Layouts collection for the current drawing
' and display whether the plot for this layout is to be centered on the media.
' It will then toggle the state of CenterPlot for "Layout1" and re-display the
' CenterPlot state for each Layout.
Dim Layouts As AcadLayouts, Layout As ACADLayout
Dim msg As String
Dim IsCentered As String
' Get layouts collection from document object
Set Layouts = ThisDrawing.Layouts
' Display current layout information
GoSub DISPLAY
' Toggle centered state for Layout1
Layouts("Layout1").PlotType = acDisplay
Layouts("Layout1").CenterPlot = Not (Layouts("Layout1").CenterPlot)
' Display new layout information
GoSub DISPLAY
Exit Sub
DISPLAY:
msg = "" ' Clear message
' Determine whether this layout is centered on the media during a plot
For Each Layout In Layouts
IsCentered = IIf(Layout.CenterPlot, " are centered ", " are not centered ")
' Format for display
msg = msg & "Objects for " & Layout.name & IsCentered & "on the media during a plot." & vbCrLf
Next
' Display layout information
MsgBox msg
Return
可视化 LISP: (vl-load-com)
(defun c:Example_CenterPlot()
;; This example will access the Layouts collection for the current drawing
;; and display whether the plot for this layout is to be centered on the media.
;; It will then toggle the state of CenterPlot for "Layout1" and re-display the
;; CenterPlot state for each Layout.
;; Get layouts collection from document object
(setq Layouts (vla-get-Layouts doc))
;; Display current layout information
(setq msg "") ;; Clear message
;; Determine whether this layout is centered on the media during a plot
(vlax-for Layout Layouts
(setq IsCentered (if (= (vla-get-CenterPlot Layout) :vlax-true) " are centered " " are not centered "))
;; Format for display
(setq msg (strcat msg "Objects for " (vla-get-Name Layout) IsCentered "on the media during a plot.\n"))
;; Display layout information
(alert msg)
;; Toggle centered state for Layout1
(vla-put-PlotType (vla-Item Layouts "Layout1") acDisplay)
(vla-put-CenterPlot (vla-Item Layouts "Layout1") (if (= (vla-get-CenterPlot (vla-Item Layouts "Layout1")) :vlax-true) :vlax-false :vlax-true))
;; Display new layout information
(alert msg)
GMT+8, 2026-11-15 12:33
