CenterMarkSize 属性 (ActiveX)
指定径向尺寸和直径尺寸的中心标记的大小。 支持的平台:仅限 Windows 属性值只读:不 类型:双 一个正实数,指定中心标记或线条的大小。 言论此属性的初始值为 0.0900。 如果该属性设置为 ,则此属性不可用。CenterTypeacCenterNone 注意:此属性将覆盖给定维度的 DIMCEN 系统变量的值。
例子VBA: Sub Example_CenterMarkSize()
' This example creates a diametric dimension in model space.
' It then changes the type of center for the dimension to
' center mark, and adjusts the size of the center mark.
Dim dimObj As AcadDimDiametric
Dim chordPoint(0 To 2) As Double
Dim farChordPoint(0 To 2) As Double
Dim leaderLength As Double
' Define the dimension
chordPoint(0) = 5#: chordPoint(1) = 3#: chordPoint(2) = 0#
farChordPoint(0) = 5#: farChordPoint(1) = 5#: farChordPoint(2) = 0#
leaderLength = 1#
' Create the diametric dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimDiametric(chordPoint, farChordPoint, leaderLength)
ZoomAll
' Change the center type to center mark and set the size of the center mark
dimObj.CenterType = acCenterMark
dimObj.CenterMarkSize = 0.1
dimObj.Update
MsgBox "The center mark size is: " & dimObj.CenterMarkSize
dimObj.CenterMarkSize = dimObj.CenterMarkSize * 2
dimObj.Update
可视化 LISP: (vl-load-com)
(defun c:Example_CenterMarkSize()
;; This example creates a diametric dimension in model space.
;; It then changes the type of center for the dimension to
;; center mark, and adjusts the size of the center mark.
;; Define the dimension
(setq chordPoint (vlax-3d-point 5 3 0)
farChordPoint (vlax-3d-point 5 5 0)
leaderLength 1)
;; Create the diametric dimension in model space
(setq dimObj (vla-AddDimDiametric modelSpace chordPoint farChordPoint leaderLength))
(vla-ZoomAll acadObj)
;; Change the center type to center mark and set the size of the center mark
(vla-put-CenterType dimObj acCenterMark)
(vla-put-CenterMarkSize dimObj 0.1)
(vla-Update dimObj)
(alert (strcat "The center mark size is: " (rtos (vla-get-CenterMarkSize dimObj) 2)))
(vla-put-CenterMarkSize dimObj (* (vla-get-CenterMarkSize dimObj) 2))
(vla-Update dimObj)
GMT+8, 2026-10-27 04:56
