Caption 属性 (ActiveX)
获取用户看到的为应用程序或菜单项显示的文本。 支持的平台:仅限 Windows 属性值只读:否(对象除外)PopupMenuItem 类型:字符串 AutoCAD 应用程序窗口中显示的标题或弹出菜单上的菜单项的标题。 言论对于菜单项,此属性是只读的,并且通过删除任何 DIESEL 字符串表达式从属性派生。Label 例子VBA: Sub Example_Caption()
' This example returns the caption for the current
' AutoCAD session.
' Get the Caption property
Dim strCaption As String
strCaption = ThisDrawing.Application.Caption
MsgBox "The caption for this session is " & ThisDrawing.Application.Caption, , "Caption Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Caption()
;; This example returns the caption for the current
;; AutoCAD session.
;; Get the Caption property
(setq strCaption (vla-get-Caption acadObj))
(alert (strcat "The caption for this session is " strCaption))
GMT+8, 2026-10-18 02:48
