Brightness 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 556| 评论: 0|原作者: admin|来自: AutoCAD
指定图像的当前亮度值。
object.Brightness
类型:GeomapImage、RasterImage、Wipeout
此属性应用于的对象。
只读:不
类型:整数
亮度值是介于 0 和 100 之间的正整数(含 0 和 100)。默认值为 50。
您可以调整图像亮度、对比度和淡入淡出以显示图像以及绘制的输出,而不会影响原始光栅图像文件。调整亮度以使图像变暗或变亮。调整对比度,使质量较差的图像更易于阅读。调整淡入淡出使矢量在图像上更易于查看,并在绘制的输出中创建水印效果。
无法调整双色调图像的亮度、对比度或淡入淡出。
Sub Example_Brightness()
    ' This example inserts a raster image and finds the current
    ' brightness of the image. It then changes the brightness
    ' of the image.
    ' This example uses the "2d Projected Polylines.jpg." found in the Sample
    ' directory. If you do not have this image, or if it is located
    ' in a different directory, insert a valid path and file name
    ' for the imageName variable below.
    Dim scalefactor As Double
    Dim rotAngleInDegree As Double, rotAngle As Double
    Dim imageName As String
    Dim raster As AcadRasterImage
    imageName = "C:/AutoCAD/sample/2d Projected Polylines.jpg"
    insertionPoint(0) = 2#: insertionPoint(1) = 2#: insertionPoint(2) = 0#
    scalefactor = 1#
    rotAngleInDegree = 0#
    rotAngle = rotAngleInDegree * 3.141592 / 180#
    On Error Resume Next
    ' Creates a raster image in model space
    Set raster = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotAngle)
    If Err.Description = "File error" Then
        MsgBox imageName & " could not be found."
        Exit Sub
    End If
    ' Find the current brightness
    ThisDrawing.Regen True
    MsgBox "The brightness is currently set to: " & raster.Brightness, vbInformation
    ' Change the brightness to 5
    raster.Brightness = 5
    MsgBox "The brightness is now set to: " & raster.Brightness, vbInformation
(defun c:Example_Brightness()
    ;; This example inserts a raster image and finds the current
    ;; brightness of the image. It then changes the brightness
    ;; of the image.
    ;; This example uses the "2d Projected Polylines.jpg" found in the Sample
    ;; directory. If you do not have this image, or if it is located
    ;; in a different directory, insert a valid path and file name
    ;; for the imageName variable below.
    (setq insertionPoint (vlax-3d-point 2 2 0)
          imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
          scalefactor 1
          rotAngleInDegree 0
          rotAngle (/ (* rotAngleInDegree 3.141592) 180))
    (if (/= (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") nil)
        (progn
            ;; Creates a raster image in model space
            (setq raster (vla-AddRaster modelSpace (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") insertionPoint scalefactor rotAngle))
            (vla-ZoomExtents acadObj)
            ;; Find the current brightness
            (vla-Regen doc :vlax-true)
            (alert (strcat "The brightness is currently set to: " (rtos (vla-get-Brightness raster) 2)))
            ;; Change the brightness to 5
            (vla-put-Brightness raster 5)
            (alert (strcat "The brightness is now set to: " (rtos (vla-get-Brightness raster) 2)))
        (alert (strcat imageName " could not be found."))
GMT+8, 2026-10-27 20:51
