BreakSpacing 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 1000| 评论: 0|原作者: admin|来自: AutoCAD
指定表的分隔间距。
object.BreakSpacing
类型: 表格
此属性应用于的对象。
只读:不
类型:双
控制破损工作台零件之间的间距。根据断裂方向,这将是水平或垂直间距。
Sub Example_BreakHeight()
    ' This example creates a table object and then breaks it into
    ' two tables.
    ' Create a new table object in model space
    Dim pt(2) As Double
    Dim modelSpace As AcadModelSpace
    Set modelSpace = ThisDrawing.modelSpace
    Dim table As AcadTable
    Set table = modelSpace.AddTable(pt, 5, 5, 10, 30)
    table.EnableBreak = True
    table.BreakSpacing = 3.5
    table.TableBreakHeight = 35#
    table.AllowManualHeights = True
    table.SetBreakHeight 0, 20#
    table.SetBreakHeight 1, 35#
    ZoomExtents
(defun c:Example_BreakHeight()
    ;; This example creates a table object and then breaks it into
    ;; two tables.
    ;; Create a new table object in model space
    (setq pt (vlax-3d-point 0 0 0))
    (setq table (vla-Addtable modelSpace pt 5 5 10 30))
    (vla-put-EnableBreak table :vlax-true)
    (vla-put-BreakSpacing table 3.5)
    (vla-put-TableBreakHeight table 35.0)
    (vla-put-AllowManualHeights table :vlax-true)
    (vla-SetBreakHeight table 0 20.0)
    (vla-SetBreakHeight table 1 35.0)
    (vla-ZoomExtents acadObj)
GMT+8, 2026-11-15 12:19
