BigFontFile 属性 (ActiveX)
指定与文本或属性关联的大字体文件的名称。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 大字体文件的名称。 言论此属性与该属性类似,只不过它用于指定亚洲语言的大字体文件。唯一有效的文件类型是 SHX。FontFile 此属性不能设置为空字符串。NULL 例子VBA: Sub Example_BigFontFile()
' BigFontFile. It then changes the value.
Dim textStyle1 As AcadTextStyle
Dim currBigFontFile As String
Dim newBigFontFile As String
Set textStyle1 = ThisDrawing.ActiveTextStyle
' Retrieve the current BigFontFile value
currBigFontFile = textStyle1.BigFontFile
MsgBox "The current value for BigFontFile is " & currBigFontFile, vbInformation, "BigFontFile Example"
' Change the value for BigFontFile
newBigFontFile = "C:/AutoCAD/Fonts/bigfont.shx"
textStyle1.BigFontFile = newBigFontFile
MsgBox "The new value for BigFontFile is " & newBigFontFile, vbInformation, "BigFontFile Example"
可视化 LISP: (vl-load-com)
(defun c:Example_BigFontFile()
;; BigFontFile. It then changes the value.
(setq textStyle1 (vla-get-ActiveTextStyle doc))
;; Retrieve the current BigFontFile value
(setq currBigFontFile (vla-get-BigFontFile textStyle1))
(alert (if (= currBigFontFile "")
(strcat "There is not big font file assigned to this font.")
(strcat "The current value for BigFontFile is " currBigFontFile))
;; Change the value for BigFontFile
(setq newBigFontFile (findfile "./Fonts/bigfont.shx"))
(vla-put-BigFontFile textStyle1 newBigFontFile)
(alert (strcat "The new value for BigFontFile is " newBigFontFile))
GMT+8, 2026-11-15 14:35
