BeepOnError 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 772| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoCAD 在检测到无效条目时是否应发出警报蜂鸣音。
object.BeepOnError
类型:PreferencesSystem
此属性应用于的对象。
只读:不
类型:布尔
  • True:发出无效条目的警报蜂鸣声。
  • False:不会发出无效条目的警报蜂鸣声。
此属性的初始值为 。False
Sub Example_BeepOnError()
    ' BeepOnError. It then changes the value, and finally
    Dim currBeepOnError As Boolean
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current BeepOnError value
    currBeepOnError = preferences.System.BeepOnError
    MsgBox "The current value for BeepOnError is " & preferences.System.BeepOnError, vbInformation, "BeepOnError Example"
    ' Change the value for BeepOnError
    preferences.System.BeepOnError = Not (currBeepOnError)
    MsgBox "The new value for BeepOnError is " & preferences.System.BeepOnError, vbInformation, "BeepOnError Example"
    ' Reset BeepOnError to its original value
    preferences.System.BeepOnError = currBeepOnError
    MsgBox "The BeepOnError value is reset to " & preferences.System.BeepOnError, vbInformation, "BeepOnError Example"
(defun c:Example_BeepOnError()
    ;; BeepOnError. It then changes the value, and finally
    ;; Retrieve the current BeepOnError value
    (setq currBeepOnError (vla-get-BeepOnError (vla-get-System preferences)))
    (alert (strcat "The current value for BeepOnError is " (if (= currBeepOnError :vlax-true) "True" "False")))
    ;; Change the value for BeepOnError
    (vla-put-BeepOnError (vla-get-System preferences) (if (= currBeepOnError :vlax-true) :vlax-false :vlax-true))
    (setq newBeepOnError (vla-get-BeepOnError (vla-get-System preferences)))
    (alert (strcat "The new value for BeepOnError is " (if (= newBeepOnError :vlax-true) "True" "False")))
    ;; Reset BeepOnError to its original value
    (vla-put-BeepOnError (vla-get-System preferences) currBeepOnError)
    (alert (strcat "The BeepOnError value is reset to " (if (= currBeepOnError :vlax-true) "True" "False")))
GMT+8, 2026-10-27 00:40
