BasePoint 属性 (ActiveX)
指定射线或构造线通过的点。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双打的三元素阵列) 表示光线或构造线经过的点的 3D 坐标。 言论没有其他评论。 例子VBA: Sub Example_BasePoint()
' This example creates a ray object. It then finds the
' base point of the ray, changes the base point, and
' queries the new base point.
Dim basePoint(0 To 2) As Double
Dim directionVec(0 To 2) As Double
Dim rayObj As AcadRay
' Establish the base point and directional vector for the ray
basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
directionVec(0) = 1#: directionVec(1) = 1#: directionVec(2) = 0#
' Create a Ray object in model space
Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, directionVec)
ThisDrawing.Regen True
MsgBox "A new Ray has been added.", vbInformation
' Define a new base point
Dim newBase(0 To 2) As Double
newBase(0) = 4#: newBase(1) = 2#: newBase(2) = 0#
' Update the ray using the new base point
rayObj.basePoint = newBase
' Query the new basepoint for the Ray
Dim currBase As Variant ' Note that return from basepoint property is Variant and not a SafeArray
Dim msg As String
currBase = rayObj.basePoint
msg = currBase(0) & ", " & currBase(1) & ", " & currBase(2)
MsgBox "We've just changed the basepoint of the new Ray to: " & msg, vbInformation
可视化 LISP: (vl-load-com)
(defun c:Example_BasePoint()
;; This example creates a ray object. It then finds the
;; base point of the ray, changes the base point, and
;; queries the new base point.
;; Establish the base point and directional vector for the ray
(setq basePoint (vlax-3d-point 3 3 0)
directionVec (vlax-3d-point 1 1 0))
;; Create a Ray object in model space
(setq rayObj (vla-AddRay modelSpace basePoint directionVec))
(vla-Regen doc :vlax-true)
(alert "A new Ray has been added.")
;; Define a new base point
(setq newBase (vlax-3d-point 4 2 0))
;; Update the ray using the new base point
(vla-put-basePoint rayObj newBase)
;; Query the new basepoint for the Ray
(setq currBase (vlax-safearray->list (vlax-variant-value (vla-get-BasePoint rayObj))))
(setq msg (strcat (rtos (nth 0 currBase) 2) ", "
(rtos (nth 1 currBase) 2) ", "
(rtos (nth 2 currBase) 2)))
(alert (strcat "We've just changed the basepoint of the new Ray to: " msg))
GMT+8, 2026-10-27 04:33
