Backward 属性 (ActiveX)
指定文本的方向。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_Backward()
' This example creates a text object in model space and
' uses the Backward property to flip the text horizontally
Dim textObj As AcadText
Dim textString As String
Dim height As Double
' Define the new Text object
textString = "Hello, World."
insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
height = 0.5
' Create the Text object in model space
Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
MsgBox "The Text oject is now forward"
textObj.Backward = True
ThisDrawing.Regen acActiveViewport
MsgBox "The Text object is now backward"
可视化 LISP: (vl-load-com)
(defun c:Example_Backward()
;; This example creates a text object in model space and
;; uses the Backward property to flip the text horizontally
;; Define the new Text object
(setq insertionPoint (vlax-3d-point 3 3 0)
textString "Hello, World."
height 0.5)
;; Create the Text object in model space
(setq textObj (vla-AddText modelSpace textString insertionPoint height))
(vla-ZoomAll acadObj)
(alert "The Text oject is now forward.")
(vla-put-Backward textObj :vlax-true)
(vla-Regen doc acActiveViewport)
(alert "The Text object is now backward.")
GMT+8, 2026-11-16 12:13
