AutoSnapMarkerColor 属性 (ActiveX)
指定 AutoSnap 标记的颜色。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acColor
言论此属性的初始值为 。acYellow 例子VBA: Sub Example_AutoSnapMarkerColor()
' This example reads and modifies the preference value that controls
' the color of the AutoSnap marker. When finished, this example resets
' the preference value back to its original value.
Dim ACADPref As AcadPreferencesDrafting
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.preferences.Drafting
originalValue = ACADPref.AutoSnapMarkerColor
MsgBox "The AutoSnapMarkerColor preference is: " & originalValue
' Modify the AutoSnapMarkerColor preference by setting it to red
ACADPref.AutoSnapMarkerColor = acRed
newValue = ACADPref.AutoSnapMarkerColor
MsgBox "The AutoSnapMarkerColor preference has been set to: " & newValue
' this preference in effect
ACADPref.AutoSnapMarkerColor = originalValue
MsgBox "The AutoSnapMarkerColor preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_AutoSnapMarkerColor()
;; This example reads and modifies the preference value that controls
;; the color of the AutoSnap marker. When finished, this example resets
;; the preference value back to its original value.
;; Get the drafting preferences object
(setq ACADPref (vla-get-Drafting preferences))
(setq originalValue (vla-get-AutoSnapMarkerColor ACADPref))
(alert (strcat "The AutoSnapMarkerColor preference is: " (itoa originalValue)))
;; Modify the AutoSnapMarkerColor preference by setting it to red
(vla-put-AutoSnapMarkerColor ACADPref acRed)
(setq newValue (vla-get-AutoSnapMarkerColor ACADPref))
(alert (strcat "The AutoSnapMarkerColor preference has been set to: " (itoa newValue)))
;; this preference in effect
(vla-put-AutoSnapMarkerColor ACADPref originalValue)
(alert (strcat "The AutoSnapMarkerColor preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-27 13:08
