AutoAudit 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 964| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoCAD 在渲染 DXFIN 或 DXBIN 交换命令后是否应执行审核。
object.AutoAudit
类型:PreferencesOpenSave
此属性应用于的对象。
只读:不
类型:布尔
  • True:在执行每个 DXFIN 或 DXBIN 命令后执行审核。
  • False:在执行每个 DXFIN 或 DXBIN 命令后不执行审核。
Sub Example_AutoAudit()
    ' AutoAudit. It then changes the value, and finally
    Dim currAutoAudit As Boolean
    Dim newAutoAudit As Boolean
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current AutoAudit value
    currAutoAudit = preferences.OpenSave.AutoAudit
    MsgBox "The current value for AutoAudit is " & currAutoAudit, vbInformation, "AutoAudit Example"
    ' Toggle the value for AutoAudit
    newAutoAudit = Not (currAutoAudit)
    preferences.OpenSave.AutoAudit = newAutoAudit
    MsgBox "The new value for AutoAudit is " & newAutoAudit, vbInformation, "AutoAudit Example"
    ' Reset AutoAudit to its original value
    preferences.OpenSave.AutoAudit = currAutoAudit
    MsgBox "The AutoAudit value is reset to " & currAutoAudit, vbInformation, "AutoAudit Example"
(defun c:Example_AutoAudit()
    ;; AutoAudit. It then changes the value, and finally
    ;; Retrieve the current AutoAudit value
    (setq currAutoAudit (vla-get-AutoAudit (vla-get-OpenSave preferences)))
    (alert (strcat "The current value for AutoAudit is " (if (= currAutoAudit :vlax-true) "True" "False")))
    ;; Toggle the value for AutoAudit
    (setq newAutoAudit (if (= currAutoAudit :vlax-true) :vlax-false :vlax-true))
    (vla-put-AutoAudit (vla-get-OpenSave preferences) newAutoAudit)
    (alert (strcat "The new value for AutoAudit is " (if (= newAutoAudit :vlax-true) "True" "False")))
    ;; Reset AutoAudit to its original value
    (vla-put-AutoAudit (vla-get-OpenSave preferences) currAutoAudit)
    (alert (strcat "The AutoAudit value is reset to " (if (= currAutoAudit :vlax-true) "True" "False")))
GMT+8, 2026-11-15 11:42
