AttachmentPoint 属性 (ActiveX)
指定 MText 对象的连接点。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acAttachmentPoint
言论连接点指定插入点与文本边界对齐的位置。所选选项可确定与文本边界相关的文本对齐方式和文本溢出。文本对齐的选项为“左”(Left)、“右”(Right) 和“居中”(Center)。文本溢出的选项包括“顶部”、“中间”(中间)和“底部”。
更改属性时,现有边界框的位置不会更改;文本只是在边界框内重新对齐。但是,该属性反映了正在使用的连接点的坐标,因此该属性的值将更改以反映对齐的更改。AttachmentPointInsertionPointInsertionPoint 例子VBA: Sub Example_AttachmentPoint()
Dim MTextObj As AcadMText
Dim width As Double
Dim text As String
Dim count As Integer
Dim attachPoint As String
Dim corner(0 To 2) As Double
corner(0) = 3#: corner(1) = 3#: corner(2) = 0#
width = 10
text = "Hello, World."
' Creates a MText object in model space
Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
For count = 1 To 9
MTextObj.AttachmentPoint = count
' Gets the attachment point of an MText object
attachPoint = Choose(MTextObj.AttachmentPoint, "TopLeft", "TopCenter", "TopRight", "MiddleLeft", "MiddleCenter", "MiddleRight", "BottomLeft", "BottomCenter", "BottomRight")
ThisDrawing.Regen True
MsgBox "The attachment point of the MText is now: " & attachPoint, vbInformation, "AttachmentPoint Example"
Next
可视化 LISP: (vl-load-com)
(defun c:Example_AttachmentPoint()
(setq corner (vlax-3d-point 3 3 0)
width 10
text "Hello, World.")
;; Creates a MText object in model space
(setq MTextObj (vla-AddMText modelSpace corner width text))
(setq count 1)
(repeat 9
(vla-put-AttachmentPoint MTextObj count)
;; Gets the attachment point of an MText object
(cond
((= (vla-get-AttachmentPoint MTextObj) 1)(setq attachPoint "TopLeft"))
((= (vla-get-AttachmentPoint MTextObj) 2)(setq attachPoint "TopCenter"))
((= (vla-get-AttachmentPoint MTextObj) 3)(setq attachPoint "TopRight"))
((= (vla-get-AttachmentPoint MTextObj) 4)(setq attachPoint "MiddleLeft"))
((= (vla-get-AttachmentPoint MTextObj) 5)(setq attachPoint "MiddleCenter"))
((= (vla-get-AttachmentPoint MTextObj) 6)(setq attachPoint "MiddleRight"))
((= (vla-get-AttachmentPoint MTextObj) 7)(setq attachPoint "BottomLeft"))
((= (vla-get-AttachmentPoint MTextObj) 8)(setq attachPoint "BottomCenter"))
((= (vla-get-AttachmentPoint MTextObj) 9)(setq attachPoint "BottomRight"))
(vla-Regen doc :vlax-true)
(alert (strcat "The attachment point of the MText is now: " attachPoint))
(setq count (1+ count))
GMT+8, 2026-10-29 04:05
