AssociativeHatch 属性 (ActiveX)
指定填充是否具有关联性。 支持的平台:仅限 Windows 属性值只读:是的 类型:布尔
言论当关联填充的边界被修改时,将更新其边界。修改非关联填充线的边界时,不会更新其边界。 只有在创建填充时才能设置关联性。有关创建填充的详细信息,请参阅该方法。AddHatch 例子VBA: Sub Example_AssociativeHatch()
' This example creates a hatch in model space.
' It then reports whether the hatch is associative.
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
' Define the hatch
patternName = "ANSI31"
PatternType = 0
bAssociativity = True
' Create the associative Hatch object
Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
' Create the outer loop for the hatch.
' An arc and a line are used to create a closed loop.
Dim outerLoop(0 To 1) As AcadEntity
Dim center(0 To 2) As Double
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
center(0) = 5: center(1) = 3: center(2) = 0
radius = 3
startAngle = 0
endAngle = 3.141592
Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle)
Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
' Append the outer loop to the hatch object
hatchObj.AppendOuterLoop (outerLoop)
' Evaluate and display the hatch
hatchObj.Evaluate
ThisDrawing.Regen True
' Return whether the hatch is associative.
Dim hatchAssoc As Boolean
hatchAssoc = hatchObj.AssociativeHatch
MsgBox "The HatchStyle is " & IIf(hatchObj.AssociativeHatch, "associative.", "not associative."), , "AssociativeHatch Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AssociativeHatch()
;; This example creates a hatch in model space.
;; It then reports whether the hatch is associative.
;; Define the hatch
(setq patternName "ANSI31"
patternType 0
bAssociativity :vlax-true)
;; Create the associative Hatch object
(setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject))
;; Create the outer loop for the hatch.
;; An arc and a line are used to create a closed loop.
(setq center (vlax-3d-point 5 3 0)
radius 3
startAngle 0
endAngle 3.141592)
(setq arc (vla-AddArc modelSpace center radius startAngle endAngle))
(setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
(setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element outerLoop 0 arc)
(vlax-safearray-put-element outerLoop 1 line)
;; Append the outer loop to the hatch object
(vla-AppendOuterLoop hatchObj outerLoop)
;; Evaluate and display the hatch
(vla-Evaluate hatchObj)
(vla-Regen doc :vlax-true)
;; Return whether the hatch is associative.
(setq hatchAssoc (vla-get-AssociativeHatch hatchObj))
(alert (strcat "The HatchStyle is " (if (= hatchAssoc :vlax-true) "associative." "not associative.")))
GMT+8, 2026-11-15 13:38
