ArrowheadSize 属性 (ActiveX)
指定标注线箭头、引线和引线箭头以及钩线的大小。 支持的平台:仅限 Windows 签名VBA: object.ArrowheadSize 属性值只读:不 类型:双 箭头的大小必须指定为正实数 >= 0.0。 言论此属性的初始值为 0.1800。 箭头大小的倍数决定了尺寸线和文本是否应适合扩展线之间。如果由 DIMBLK 设置,则此属性还用于缩放箭头块。当 DIMTSZ 不是零时,此属性不起作用。 注意:此属性将覆盖给定维度的 DIMASZ 系统变量的值。
例子VBA: Sub Example_ArrowHeadSize()
' This example creates a Dim3PointAngular object in model space
' and then alters the visible appearance (size) of its arrowheads
' using the ArrowHeadSize property
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Read and display current arrowhead size
MsgBox "The arrowhead size for this object is currently set to: " & DimPointAngularObj.ArrowheadSize
' Alter the arrowhead size property for this object
DimPointAngularObj.ArrowheadSize = 0.5
' Read and display new arrowhead size setting
MsgBox "The arrowhead size for this object is now set to: " & DimPointAngularObj.ArrowheadSize
可视化 LISP: (vl-load-com)
(defun c:Example_ArrowHeadSize()
;; This example creates a Dim3PointAngular object in model space
;; and then alters the visible appearance (size) of its arrowheads
;; using the ArrowHeadSize property
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Read and display current arrowhead size
(alert (strcat "The arrowhead size for this object is currently set to: " (rtos (vla-get-ArrowheadSize DimPointAngularObj) 2)))
;; Alter the arrowhead size property for this object
(vla-put-ArrowheadSize DimPointAngularObj 0.5)
;; Read and display new arrowhead size setting
(alert (strcat "The arrowhead size for this object is now set to: " (rtos (vla-get-ArrowheadSize DimPointAngularObj) 2)))
GMT+8, 2026-10-28 10:52
