Area 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 766| 评论: 0|原作者: admin|来自: AutoCAD
Area 属性 (ActiveX)
指定圆弧、圆、椭圆、填充线、轻量级折线、折线、区域或平面闭合样条的封闭区域。
object.Area
类型:圆弧、圆形、椭圆、剖面线、LWPolyline、折线、区域、样条
此属性应用于的对象。
只读:否,对于对象;是,对于所有其他对象Circle
类型:双
以正方形图形单位指定的对象的面积。
剖面线对象:
填充的组合区域的总面积。
宽折线:
该区域由宽度的中心定义。
地区:
面积等于该区域中所有对象的总面积。
打开对象,例如圆弧、样条曲线和打开多段线:
面积的计算方式就好像一条直线连接起点和终点一样。
Sub Example_Area()
    ' This example creates a polyline object and
    ' then uses the area property to find the
    ' area of that polyline.
    Dim points(0 To 5) As Double
    Dim plineArea As Double
    ' Establish the points for the Polyline
    points(0) = 3: points(1) = 7
    points(2) = 9: points(3) = 2
    points(4) = 3: points(5) = 5
    ' Create the polyline in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ' Close the polyline and update display of it
    plineObj.Closed = True
    plineObj.Update
    ZoomAll
    ' Get the area of the polyline
    plineArea = plineObj.Area
    MsgBox "The area of the new Polyline is: " & plineArea, vbInformation, "Area Example"
(defun c:Example_Area()
    ;; This example creates a polyline object and
    ;; then uses the area property to find the
    ;; area of that polyline.
    ;; Establish the points for the Polyline
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
    (vlax-safearray-fill points '(3 7
				  9 2
				  3 5
    ;; Create the polyline in model space
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    ;; Close the polyline and update display of it
    (vla-put-Closed plineObj :vlax-true)
    (vla-Update plineObj)
    (vla-ZoomAll acadObj)
    ;; Get the area of the polyline
    (setq plineArea (vla-get-Area plineObj))
    (alert (strcat "The area of the new Polyline is: " (rtos plineArea 2)))
GMT+8, 2026-10-27 07:10
