ArcSmoothness 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 802| 评论: 0|原作者: admin|来自: AutoCAD
指定圆、圆弧和椭圆的平滑度。
object.ArcSmoothness
类型:PViewport、视口
此属性应用于的对象。
只读:不
类型:整数
从 1 到 20,000 的正整数。
此属性的初始值为 100。
数字越大,对象越平滑,但 AutoCAD 需要更多时间来重新生成它们。可以通过将此属性设置为较低的绘图值和增加渲染值来提高性能。有效范围为 1 到 20,000。
Sub Example_ArcSmoothness()
    ' ArcSmoothness. It then changes the value, and finally
    Dim currArcSmoothness As Integer
    Dim newArcSmoothness As Integer
    ' Retrieve the current ArcSmoothness value
    currArcSmoothness = ThisDrawing.ActiveViewport.ArcSmoothness
    MsgBox "The current value for ArcSmoothness is " & currArcSmoothness, vbInformation, "ArcSmoothness Example"
    ' Change the value for ArcSmoothness
    newArcSmoothness = 2001
    ThisDrawing.ActiveViewport.ArcSmoothness = newArcSmoothness
    MsgBox "The new value for ArcSmoothness is " & newArcSmoothness, vbInformation, "ArcSmoothness Example"
    ' Reset ArcSmoothness to its original value
    ThisDrawing.ActiveViewport.ArcSmoothness = currArcSmoothness
    MsgBox "The ArcSmoothness value is reset to " & currArcSmoothness, vbInformation, "ArcSmoothness Example"
(defun c:Example_ArcSmoothness()
    ;; ArcSmoothness. It then changes the value, and finally
    ;; Retrieve the current ArcSmoothness value
    (setq currArcSmoothness (vla-get-ArcSmoothness (vla-get-ActiveViewport doc)))
    (alert (strcat "The current value for ArcSmoothness is " (itoa currArcSmoothness)))
    ;; Change the value for ArcSmoothness
    (setq newArcSmoothness 2001)
    (vla-put-ArcSmoothness (vla-get-ActiveViewport doc) newArcSmoothness)
    (alert (strcat "The new value for ArcSmoothness is " (itoa newArcSmoothness)))
    ;; Reset ArcSmoothness to its original value
    (vla-put-ArcSmoothness (vla-get-ActiveViewport doc) currArcSmoothness)
    (alert (strcat "The ArcSmoothness value is reset to " (itoa currArcSmoothness)))
GMT+8, 2026-10-27 04:35
