ArcLength 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 595| 评论: 0|原作者: admin|来自: AutoCAD
获取圆弧的长度。
object.ArcLength
类型:弧形
此属性应用于的对象。
只读:是的
类型:双
圆弧的长度。
Sub Example_ArcLength()
    ' This example creates an Arc in model space and returns the length of the new Arc
    Dim arcObj As AcadArc
    Dim centerPoint(0 To 2)  As Double
    Dim radius As Double
    Dim startAngleInDegree As Double, endAngleInDegree As Double
    Dim startAngleInRadian As Double, endAngleInRadian As Double
    ' Define the Arc
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius = 5#
    startAngleInDegree = 10#: endAngleInDegree = 230#
    ' Convert the angles in degrees to angles in radians
    startAngleInRadian = startAngleInDegree * 3.141592 / 180#
    endAngleInRadian = endAngleInDegree * 3.141592 / 180#
    ' Create the arc object in model space
    Set arcObj = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngleInRadian, endAngleInRadian)
    ' Return length of new arc
    MsgBox "The length of the new Arc is: " & arcObj.ArcLength
(defun c:Example_ArcLength()
    ;; This example creates an Arc in model space and returns the length of the new Arc
    ;; Define the Arc
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5
          startAngleInDegree 10
          endAngleInDegree 230)
    ;; Convert the angles in degrees to angles in radians
    (setq startAngleInRadian (/ (* startAngleInDegree 3.141592) 180))
    (setq endAngleInRadian (/ (* endAngleInDegree 3.141592) 180))
    ;; Create the arc object in model space
    (setq arcObj (vla-AddArc modelSpace centerPoint radius startAngleInRadian endAngleInRadian))
    (vla-ZoomAll acadObj)
    ;; Return length of new arc
    (alert (strcat "The length of the new Arc is: " (rtos (vla-get-ArcLength arcObj) 2)))
GMT+8, 2026-10-27 13:08
