Application 属性 (ActiveX)
获取 Application 对象。 支持的平台:仅限 Windows 言论该对象表示应用程序的框架控件和路径设置,并提供在对象层次结构中向下导航的方法。Application 例子VBA: Sub Example_Application()
' This example creates a line and then uses the
' Application property of the line to return the
' application name.
Dim lineObj As AcadLine
Dim myApp As AcadApplication
' Create a new line reference
startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
lineObj.Update
' Return the application for the object
Set myApp = lineObj.Application
' Display the name of the application
MsgBox "The application name is: " & myApp.name, vbInformation, "Application Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Application()
;; This example creates a line and then uses the
;; Application property of the line to return the
;; application name.
;; Create a new line reference
(setq startPoint (vlax-3d-point 0 0 0)
endPoint (vlax-3d-point 2 2 0))
(vla-Update lineObj)
;; Return the application for the object
(setq myApp (vla-get-Application lineObj))
;; Display the name of the application
(alert (strcat "The application name is: " (vla-get-Name myApp)))
GMT+8, 2026-10-28 06:10
