AngleVertex 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 849| 评论: 0|原作者: admin|来自: AutoCAD
指定三点角尺寸的角度顶点。
object.AngleVertex
类型:Dim3PointAngular
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
表示角度顶点的 3D 坐标。
Sub Example_AngleVertex()
    ' This example creates a Dim3PointAngular object in model space
    ' and then alters its angle vertex
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double, NewAngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    Dim CurrentVertex As Variant
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    NewAngleVertex(0) = 1: NewAngleVertex(1) = 1: NewAngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Display current vertex
    CurrentVertex = DimPointAngularObj.AngleVertex
    MsgBox "The angle vertex of the new object is set to:" & vbCrLf & _
            CurrentVertex(0) & vbCrLf & _
            CurrentVertex(1) & vbCrLf & _
            CurrentVertex(2)
    ' Alter vertex setting for this object
    DimPointAngularObj.AngleVertex = NewAngleVertex
    ' Display new vertex settings
    MsgBox "The angle vertex of the object has been reset to:" & vbCrLf & _
            CurrentVertex(2)
(defun c:Example_AngleVertex()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and then alters its angle vertex
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 2 5 0)
          NewAngleVertex (vlax-3d-point 1 1 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Display current vertex
    (setq CurrentVertex (vla-get-AngleVertex DimPointAngularObj))
    (alert (strcat "The angle vertex of the new object is set to:\n"
                   (rtos (vlax-safearray-get-element (vlax-variant-value CurrentVertex) 0) 2) "\n"
                   (rtos (vlax-safearray-get-element (vlax-variant-value CurrentVertex) 1) 2) "\n"
                   (rtos (vlax-safearray-get-element (vlax-variant-value CurrentVertex) 2) 2)))
    ;; Alter vertex setting for this object
    (vla-put-AngleVertex DimPointAngularObj NewAngleVertex)
    ;; Display new vertex settings
    (alert (strcat "The angle vertex of the object has been reset to:\n"
GMT+8, 2026-10-27 05:16
