Angle 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 638| 评论: 0|原作者: admin|来自: AutoCAD
Angle 属性 (ActiveX)
获取直线的角度。
object.Angle
类型:线
此属性应用于的对象。
只读:是的
类型:双
线的角度(以弧度为单位)。角度测量从 X 轴开始,沿逆时针方向进行。
Sub Example_Angle()
    ' This example adds a line in model space and returns the angle of the new line
    Dim lineObj As AcadLine
    Dim startPoint(0 To 2) As Double, endPoint(0 To 2)  As Double
    ' Define the start and end points for the line
    startPoint(0) = 1: startPoint(1) = 1: startPoint(2) = 0
    endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0
    ' Create the line in model space
    MsgBox "The angle of the new Line is: " & lineObj.angle
(defun c:Example_Angle()
    ;; This example adds a line in model space and returns the angle of the new line
    ;; Define the start and end points for the line
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    ;; Create the line in model space
    (vla-ZoomAll acadObj)
    (alert (strcat "The angle of the new Line is: " (rtos (vla-get-Angle lineObj) 2)))
GMT+8, 2026-10-27 04:24
