AltUnitsScale 属性 (ActiveX)
指定备用单位的比例因子。 支持的平台:仅限 Windows 签名VBA: object.AltUnitsScale
属性值只读:不 类型:双 应用于备用单位的比例因子。 言论如果该属性处于打开状态,则此属性会将线性尺寸乘以一个因子,以在备用度量系统中生成一个值。初始值表示以英寸为单位的毫米数。AltUnits 该属性的初始值为 25.4000。 注意:此属性将覆盖给定维度的 DIMALTF 系统变量的值。
例子VBA: Sub Example_AltUnitsScale()
' uses AltUnitsScale to cycle through some common scales
' for the alternate dimension
Dim dimObj As AcadDimAligned
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5: point2(1) = 5: point2(2) = 0
' Enable display of alternate units
dimObj.AltUnits = True
' Cycle through some common dimension scales
dimObj.AltUnitsScale = 1 ' Change scale to Inches
MsgBox "The alternate dimension units are now set to inches"
dimObj.AltUnitsScale = 25.4 ' Change scale to Millimeters (default)
MsgBox "The alternate dimension units are now set to millimeters"
dimObj.AltUnitsScale = 2.54 ' Change scale to Centimeters
MsgBox "The alternate dimension units are now set to centimeters"
可视化 LISP: (vl-load-com)
(defun c:Example_AltUnitsScale()
;; uses AltUnitsScale to cycle through some common scales
;; for the alternate dimension
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5 5 0)
(vla-ZoomAll acadObj)
;; Enable display of alternate units
(vla-put-AltUnits dimObj :vlax-true)
;; Cycle through some common dimension scales
(vla-put-AltUnitsScale dimObj 1) ;; Change scale to Inches
(alert "The alternate dimension units are now set to inches.")
(vla-put-AltUnitsScale dimObj 25.4) ;; Change scale to Millimeters (default)
(alert "The alternate dimension units are now set to millimeters.")
(vla-put-AltUnitsScale dimObj 2.54) ;; Change scale to Centimeters
(alert "The alternate dimension units are now set to centimeters.")
GMT+8, 2026-11-15 12:49
