AltUnitsPrecision 属性 (ActiveX)
指定备用单位中的小数位数。 支持的平台:仅限 Windows 签名VBA: object.AltUnitsPrecision
属性值只读:不 类型:枚举acDimPrecision 使用以下常量之一指定精度:
言论此属性的初始值为 。acDimPrecisionTwo 注意:此属性将覆盖给定维度的 DIMALTD 系统变量的值。
例子VBA: Sub Example_AltUnitsPrecision()
' uses AltUnitsPrecision to allow the user to change the
' precision of the alternate dimension
Dim dimObj As AcadDimAligned
Dim oldPrecision As String, newPrecision As String
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
' Enable alternate unit display
dimObj.AltUnits = True
' Store old Precision value as default for input box
oldPrecision = dimObj.AltUnitsPrecision
' Allow the user to change the precision for the alternate dimension
newPrecision = InputBox("Enter a new precision for the alternate dimension. The value must range from 0 to 8.", "Alternate Dimension Precision", oldPrecision)
Select Case newPrecision
Case 0: newPrecision = acDimPrecisionZero
Case 1: newPrecision = acDimPrecisionOne
Case 2: newPrecision = acDimPrecisionTwo
Case 3: newPrecision = acDimPrecisionThree
Case 4: newPrecision = acDimPrecisionFour
Case 5: newPrecision = acDimPrecisionFive
Case 6: newPrecision = acDimPrecisionSix
Case 7: newPrecision = acDimPrecisionSeven
Case 8: newPrecision = acDimPrecisionEight
Case Else
MsgBox "The alternate precision has not been changed."
Exit Sub
End Select
dimObj.AltUnitsPrecision = newPrecision ' Commit changes to precision
' Read back and display the alternate dimension precision
newPrecision = dimObj.AltUnitsPrecision
MsgBox "The alternate dimension precision has been set to " & newPrecision & " decimal places"
可视化 LISP: (vl-load-com)
(defun c:Example_AltUnitsPrecision()
;; uses AltUnitsPrecision to allow the user to change the
;; precision of the alternate dimension
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5.12345678 5 0)
;; Enable alternate unit display
(vla-put-AltUnits dimObj :vlax-true)
(vla-ZoomAll acadObj)
;; Store old Precision value as default for input box
(setq oldPrecision (vla-get-AltUnitsPrecision dimObj))
;; Allow the user to change the precision for the alternate dimension
(if (= (setq newPrecision (getint "\nEnter a new precision for the alternate dimension (0-8): ")) nil) (setq newPrecision oldPrecision))
(cond
((= newPrecision 0)(setq newPrecision acDimPrecisionZero))
((= newPrecision 1)(setq newPrecision acDimPrecisionOne))
((= newPrecision 2)(setq newPrecision acDimPrecisionTwo))
((= newPrecision 3)(setq newPrecision acDimPrecisionThree))
((= newPrecision 4)(setq newPrecision acDimPrecisionFour))
((= newPrecision 5)(setq newPrecision acDimPrecisionFive))
((= newPrecision 6)(setq newPrecision acDimPrecisionSix))
((= newPrecision 7)(setq newPrecision acDimPrecisionSeven))
((= newPrecision 8)(setq newPrecision acDimPrecisionEight))
((progn (alert "The alternate precision has not been changed.")(setq newPrecision oldPrecision)))
(vla-put-AltUnitsPrecision dimObj newPrecision) ;; Commit changes to precision
;; Read back and display the alternate dimension precision
(setq newPrecision (vla-get-AltUnitsPrecision dimObj))
(alert (strcat "The alternate dimension precision has been set to " (itoa newPrecision) " decimal places."))
GMT+8, 2026-10-27 01:22
