AltUnits 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 610| 评论: 0|原作者: admin|来自: AutoCAD
启用以备用单位进行尺寸标注。
object.AltUnits
类型:DimAlignedDimArcLengthDimDiametricDimOrdinateDimRadial、DimRadialLargeDimRotated
此属性应用于的对象。
只读:
类型:布尔
  • True:启用备用单位的尺寸标注。
  • False:禁用备用单位的尺寸标注。
此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMALT 系统变量的值。
Sub Example_AltUnits()
   ' uses AltUnits to toggle the alternate dimension units on and off
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5: point2(1) = 5: point2(2) = 0
    ' Toggle alternate unit display
Toggle:
    Select Case MsgBox("Press OK to toggle the display of alternate dimensions", vbOKCancel)
        Case vbOK
            ' Toggle the alternate dimension display
            dimObj.AltUnits = Not (dimObj.AltUnits)
        Case vbCancel
            Exit Sub
    End Select
    ' Display status of alternate units display
    If dimObj.AltUnits Then
        MsgBox "Alternate units display is on."
    Else
        MsgBox "Alternate units display is off."
    End If
    GoTo Toggle
(defun c:Example_AltUnits()
    ;; uses AltUnits to toggle the alternate dimension units on and off
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5 5 0)
    (vla-ZoomAll acadObj)
    ;; Toggle alternate unit display
    (setq originalValue (vla-get-AltUnits dimObj))
    (alert "Toggling the display of alternate units.")
    ;; Toggle the display of trailing zeros for the alternate dimension tolerance value
    (vla-put-AltUnits dimObj (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-AltUnits dimObj))
    (alert "Toggling the display of alternate units to original value.")
    (vla-put-AltUnits dimObj (if (= newValue :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-9-16 20:15
