AltToleranceSuppressLeadingZeros 属性 (ActiveX)
指定禁止在备用维度值中显示前导零。 支持的平台:仅限 Windows 签名VBA: object.AltToleranceSuppressLeadingZeros
属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此属性将覆盖给定维度的 DIMALTTZ 系统变量的值。
例子VBA: Sub Example_AltToleranceSuppressLeadingZeros()
' uses AltToleranceSuppressLeadingZeros to toggle the display of leading zeros
' in the alternate dimension tolerance display
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 5.01: point2(1) = 5: point2(2) = 0
' Set up alternate unit tolerance display
dimObj.AltUnits = True
dimObj.ToleranceDisplay = acTolLimits
Toggle:
Select Case MsgBox("Press OK to toggle the display of leading zeros in the alternate dimension tolerance", vbOKCancel)
Case vbOK
' Toggle the display of leading zeros for the alternate dimension tolerance value
dimObj.AltToleranceSuppressLeadingZeros = Not (dimObj.AltToleranceSuppressLeadingZeros)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_AltToleranceSuppressLeadingZeros()
;; uses AltToleranceSuppressLeadingZeros to toggle the display of leading zeros
;; in the alternate dimension tolerance display
;; Define the dimension
point2 (vlax-3d-point 5.01 5 0)
;; Set up alternate unit tolerance display
(vla-put-AltUnits dimObj :vlax-true)
(vla-put-ToleranceDisplay dimObj acTolLimits)
(vla-ZoomAll acadObj)
;; Toggle the display of leading zeros for the alternate dimension tolerance value
(vla-put-AltToleranceSuppressLeadingZeros dimObj (if (= (vla-get-AltToleranceSuppressLeadingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
(alert "Suppression of leading zeros in the alternate dimension tolerance toggled.")
;; Toggle the display of leading zeros for the alternate dimension tolerance value back to previous state
(alert "Suppression of leading zeros in the alternate dimension tolerance toggled back.")
GMT+8, 2026-10-28 04:50
