AltTolerancePrecision 属性 (ActiveX)
指定公差值在备用尺寸中的精度。 支持的平台:仅限 Windows 签名VBA: object.AltTolerancePrecision
属性值只读:不 类型:枚举acDimPrecision
言论此属性的初始值为 。acDimPrecisionTwo 仅当该属性设置为除 以外的任何值时,此属性才可用。ToleranceDisplayacTolNone 注意:此属性将覆盖给定维度的 DIMALTTD 系统变量的值。
例子VBA: Sub Example_AltTolerancePrecision()
' uses AltTolerancePrecision to allow the user to change the
' precision of the alternate dimension tolerance
Dim dimObj As AcadDimAligned
Dim oldTolerance As String, newTolerance As String
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
' Enable alternate unit display
dimObj.AltUnits = True
dimObj.ToleranceDisplay = acTolLimits
' Store old tolerance value as default for input box
oldTolerance = dimObj.AltTolerancePrecision
' Allow the user to change the precision for the alternate dimension tolerance
newTolerance = InputBox("Enter a new tolerance precision for the alternate dimension. The value must range from 0 to 8.", "Alternate Dimension Tolerance Precision", oldTolerance)
Select Case newTolerance
Case 0: newTolerance = acDimPrecisionZero
Case 1: newTolerance = acDimPrecisionOne
Case 2: newTolerance = acDimPrecisionTwo
Case 3: newTolerance = acDimPrecisionThree
Case 4: newTolerance = acDimPrecisionFour
Case 5: newTolerance = acDimPrecisionFive
Case 6: newTolerance = acDimPrecisionSix
Case 7: newTolerance = acDimPrecisionSeven
Case 8: newTolerance = acDimPrecisionEight
Case Else
MsgBox "The alternate tolerance precision has not been changed."
Exit Sub
End Select
dimObj.AltTolerancePrecision = newTolerance ' Commit changes to tolerance precision
' Read back and display the alternate dimension tolerance precision
newTolerance = dimObj.AltTolerancePrecision
MsgBox "The tolerance precision has been set to " & newTolerance & " decimal places"
可视化 LISP: (vl-load-com)
(defun c:Example_AltTolerancePrecision()
;; uses AltTolerancePrecision to allow the user to change the
;; precision of the alternate dimension tolerance
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5.12345678 5 0)
;; Enable alternate unit display
(vla-put-AltUnits dimObj :vlax-true)
(vla-put-ToleranceDisplay dimObj acTolLimits)
(vla-ZoomAll acadObj)
;; Store old tolerance value as default for input box
(setq oldTolerance (vla-get-AltTolerancePrecision dimObj))
;; Allow the user to change the precision for the alternate dimension tolerance
(setq newTolerance (vla-GetInteger (vla-get-Utility doc) (strcat "\nEnter a new tolerance precision for the alternate dimension (0 to 8) <" (itoa oldTolerance) ">: ")))
(if (= newTolerance nil) (setq newTolerance oldTolerance))
(setq newTolerance (cond
((= newTolerance 0) acDimPrecisionZero)
((= newTolerance 1) acDimPrecisionOne)
((= newTolerance 2) acDimPrecisionTwo)
((= newTolerance 3) acDimPrecisionThree)
((= newTolerance 4) acDimPrecisionFour)
((= newTolerance 5) acDimPrecisionFive)
((= newTolerance 6) acDimPrecisionSix)
((= newTolerance 7) acDimPrecisionSeven)
((= newTolerance 8) acDimPrecisionEight)
(progn (setq newTolerance nil) (alert "The alternate tolerance precision has not been changed."))
(if (/= newTolerance nil)
(progn
(vla-put-AltTolerancePrecision dimObj newTolerance) ;; Commit changes to tolerance precision
;; Read back and display the alternate dimension tolerance precision
(alert (strcat "The tolerance precision has been set to " (itoa (vla-get-AltTolerancePrecision dimObj)) " decimal places"))
GMT+8, 2026-10-28 03:55
