AltTextPrefix 属性 (ActiveX)
指定除 angular 之外的所有尺寸类型的备用尺寸测量的前缀。 支持的平台:仅限 Windows 签名VBA: object.AltTextPrefix
属性值只读:不 类型:字符串 备用维度的前缀。 言论此属性的初始值为“”。 若要关闭已建立的前缀,请将此属性设置为等于单个句点 (.)。 注意:此属性将覆盖给定维度的 DIMAPOST 系统变量的值。
例子VBA: Sub Example_AltTextPrefix()
' uses AltTextPrefix to allow the user to change the text prefix for the
' alternate dimension
Dim dimObj As AcadDimAligned
Dim prefix As String
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5: point2(1) = 5: point2(2) = 0
' Enable alternate unit display
dimObj.AltUnits = True
' Allow the user to change the text prefix for the alternate dimension
prefix = InputBox("Enter a new text prefix for the alternate dimension", "Alternate Dimension Prefix", "PREFIX:")
dimObj.AltTextPrefix = prefix ' Commit changes to prefix
' Read back and display the alternate dimension text prefix
prefix = dimObj.AltTextPrefix
If prefix <> "" Then
MsgBox "The prefix of the alternate dimension has been changed to: " & prefix
Else
MsgBox "The prefix of the alternate dimension has been removed"
End If
可视化 LISP: (vl-load-com)
(defun c:Example_AltTextPrefix()
;; uses AltTextPrefix to allow the user to change the text prefix for the
;; alternate dimension
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5 5 0)
;; Enable alternate unit display
(vla-put-AltUnits dimObj :vlax-true)
(vla-ZoomAll acadObj)
;; Allow the user to change the text prefix for the alternate dimension
(setq prefix (vla-GetString (vla-get-Utility doc) :vlax-false "\nEnter a new text prefix for the alternate dimension: "))
(vla-put-AltTextPrefix dimObj prefix) ;; Commit changes to prefix
;; Read back and display the alternate dimension text prefix
(setq prefix (vla-get-AltTextPrefix dimObj))
(if (/= prefix "")
(alert (strcat "The prefix of the alternate dimension has been changed to: " prefix))
(alert "The prefix of the alternate dimension has been removed")
GMT+8, 2026-10-27 04:59
