AltSuppressZeroFeet 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 580| 评论: 0|原作者: admin|来自: AutoCAD
指定在备用尺寸值中隐含零英尺测量值。
object.AltSuppressZeroFeet
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止显示零英尺测量值。
  • False:不要禁止显示零英尺测量值。
此属性的初始值为 False。
注意:此属性将覆盖给定维度的 DIMALTZ 系统变量的值。
Sub Example_AltSuppressZeroFeet()
   ' uses AltSuppressZeroFeet to suppress or view the display of
   ' zero feet in the alternate dimension display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5: point2(1) = 5: point2(2) = 0
    ' Enable alternate unit display
    dimObj.AltUnits = True
    ' Set the dimension display to a style that works with AltSuppressZeroFeet
    dimObj.AltUnitsFormat = acDimLArchitectural
    dimObj.AltUnitsScale = 2    ' Set the alternate unit scale to be a multiple of 2
Toggle:
    Select Case MsgBox("Press OK to suppress or view the display of zero feet in the alternate dimension", vbOKCancel)
        Case vbOK
            ' Toggle the display of zero feet for the alternate dimension value
            dimObj.AltSuppressZeroFeet = Not (dimObj.AltSuppressZeroFeet)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_AltSuppressZeroFeet()
    ;; uses AltSuppressZeroFeet to suppress or view the display of
    ;; zero feet in the alternate dimension display
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5 5 0)
    ;; Enable alternate unit display
    (setq originalValue (vla-get-AltSuppressZeroFeet dimObj))
    (vla-put-AltUnits dimObj :vlax-true)
    ;; Set the dimension display to a style that works with AltSuppressZeroFeet
    (vla-put-AltUnitsFormat dimObj acDimLArchitectural)
    (vla-put-AltUnitsScale dimObj 2)    ;; Set the alternate unit scale to be a multiple of 2
    (vla-ZoomAll acadObj)
    (alert "Toggling the display of zero feet in the alternate tolerance.")
    (vla-put-AltSuppressZeroFeet dimObj (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-AltSuppressZeroFeet dimObj))
    (alert "Toggling the display of zero feet in the alternate tolerance to original value.")
    (vla-put-AltSuppressZeroFeet dimObj (if (= newValue :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-10-27 05:31
