AlignmentPointAcquisition 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 782| 评论: 0|原作者: admin|来自: AutoCAD
指定如何获取自动对齐点。
object.AlignmentPointAcquisition
类型:首选项起草
此属性应用于的对象。
只读:不
类型:枚举acAlignmentPointAcquisition
  • acAlignPntAcquisitionAutomatic:自动对齐点是自动获取的。
  • acAlignPntAcquisitionShiftToAcquire:用户必须使用 Shift 键获取自动对齐点。
此属性的初始值为 。acAlignPntAcquisitionAutomatic
Sub Example_AlignmentPointAcquisition()
    ' This example reads and modifies the preference value that controls
    ' how AutoAlignment points are acquired. When finished, this example resets
    ' the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDrafting
    ' Get the drafting preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Drafting
    originalValue = ACADPref.AlignmentPointAcquisition
    MsgBox "The AlignmentPointAcquisition preference is: " & originalValue
    ' Toggle and display the AlignmentPointAcquisition preference
    If ACADPref.AlignmentPointAcquisition = acAlignPntAcquisitionAutomatic Then
        ACADPref.AlignmentPointAcquisition = acAlignPntAcquisitionShiftToAcquire
    Else
    End If
    newValue = ACADPref.AlignmentPointAcquisition
    MsgBox "The AlignmentPointAcquisition preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.AlignmentPointAcquisition = originalValue
    MsgBox "The AlignmentPointAcquisition preference was reset back to: " & originalValue
(defun c:Example_AlignmentPointAcquisition()
    ;; This example reads and modifies the preference value that controls
    ;; how AutoAlignment points are acquired. When finished, this example resets
    ;; the preference value back to its original value.
    ;; Get the drafting preferences object
    (setq ACADPref (vla-get-Drafting (vla-get-Preferences acadObj)))
    (setq originalValue (vla-get-AlignmentPointAcquisition ACADPref))
    (alert (strcat "The AlignmentPointAcquisition preference is: " (itoa originalValue)))
    ;; Toggle and display the AlignmentPointAcquisition preference
    (if (= (vla-get-AlignmentPointAcquisition ACADPref) acAlignPntAcquisitionAutomatic)
        (vla-put-AlignmentPointAcquisition ACADPref acAlignPntAcquisitionShiftToAcquire)
        (vla-put-AlignmentPointAcquisition ACADPref acAlignPntAcquisitionAutomatic)
    (setq newValue (vla-get-AlignmentPointAcquisition ACADPref))
    (alert (strcat "The AlignmentPointAcquisition preference has been set to: " (itoa newValue)))
    ;;         this preference in effect
    (vla-put-AlignmentPointAcquisition ACADPref originalValue)
    (alert (strcat "The AlignmentPointAcquisition preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-28 05:24
