ADCInsertUnitsDefaultSource 属性 (ActiveX)
确定要自动用于设计中心中对象的单位,以用于未指定插入单位的源图形。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acInsertUnits
言论此属性的初始值为 。acInsertUnitsUnitless 注意:此属性的值存储在 INSUNITSDEFSOURCE 系统变量中。
例子VBA: Sub Example_ADCInsertUnitsDefaultSource()
' This example reads and modifies the ADCInsertUnitsDefaultSource
' preference value.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesUser
Dim originalValue As Integer, newValue As Integer
' Get the user preferences object
Set ACADPref = ThisDrawing.Application.preferences.User
originalValue = ACADPref.ADCInsertUnitsDefaultSource
MsgBox "The ADCInsertUnitsDefaultSource preference is set to: " & originalValue
' Modify the ADCInsertUnitsDefaultSource preference by toggling the value
ACADPref.ADCInsertUnitsDefaultSource = acInsertUnitsMillimeters
MsgBox "The ADCInsertUnitsDefaultSource preference has been set to: " & ACADPref.ADCInsertUnitsDefaultSource
ACADPref.ADCInsertUnitsDefaultSource = originalValue
MsgBox "The ADCInsertUnitsDefaultSource preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_ADCInsertUnitsDefaultSource()
;; This example reads and modifies the ADCInsertUnitsDefaultSource
;; preference value.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the user preferences object
(setq pref (vla-get-Preferences acadObj))
(setq user (vla-get-User pref))
(setq originalValue (vla-get-ADCInsertUnitsDefaultSource user))
(alert (strcat "The ADCInsertUnitsDefaultSource preference is set to: " (itoa originalValue)))
;; Modify the ADCInsertUnitsDefaultSource preference by toggling the value
(vla-put-ADCInsertUnitsDefaultSource user acInsertUnitsMillimeters)
(alert (strcat "The ADCInsertUnitsDefaultSource preference has been set to: " (itoa (vla-get-ADCInsertUnitsDefaultSource user))))
;; Restore the preference back to its original value
(vla-put-ADCInsertUnitsDefaultSource user originalValue)
(alert (strcat "The ADCInsertUnitsDefaultSource preference was restored back to: " (itoa originalValue)))
GMT+8, 2026-10-27 04:16
