ActiveViewport 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 781| 评论: 0|原作者: admin|来自: AutoCAD
指定图形的活动视口。
object.ActiveViewport
类别: 文档
此属性应用于的对象。
只读:不
类型:视口
图形的活动视口。
只有在将视口重置为活动视口后,对当前活动视口所做的更改才会可见。若要重置活动视口,只需使用更新的视口对象调用此属性即可。
使用该属性可确定视口当前是否处于活动状态。StatusID
您可以循环访问现有视口以查找特定视口。为此,请首先使用该属性确定所需视口所在的视口配置的名称。此外,如果视口配置已拆分,则可以通过 和 属性来标识配置上的每个单独视口。NameLowerLeftCornerUpperRightCorner
and 属性表示视口在显示器上的图形位置。这些属性定义如下(以四向拆分为例):LowerLeftCornerUpperRightCorner
视口 1— = (0, .5), = (.5, 1)LowerLeftCornerUpperRightCorner
视口 2— = (.5, .5), = (1, 1)LowerLeftCornerUpperRightCorner
视口 3— = (0, 0), = (.5, .5)LowerLeftCornerUpperRightCorner
视口 4— = (.5, 0), = (1, .5)LowerLeftCornerUpperRightCorner
Sub Example_ActiveViewport()
    ' This example returns the current viewport.
    ' It creates a new viewport and makes it active, and
    ' Then it splits the viewport into four windows.
    ' It then takes one of the four windows, and splits that
    ' window horizontally into half.
    Dim currViewport As AcadViewport
    Dim newViewport As AcadViewport
    ' Returns current viewport of active document
    Set currViewport = ThisDrawing.ActiveViewport
    MsgBox "The current viewport is " & currViewport.name, vbInformation, "ActiveViewport Example"
    ' Create a new viewport and make it active
    Set newViewport = ThisDrawing.Viewports.Add("TESTVIEWPORT")
    ThisDrawing.ActiveViewport = newViewport
    MsgBox "The new active viewport is " & newViewport.name, vbInformation, "ActiveViewport Example"
    ' Split the viewport in four windows
    newViewport.Split acViewport4
    ' Make the newly split viewport active
    ' Note that current drawing layout will show four windows.
    ' However, only one of the windows will be active.
    ' The following code sets the lower-left corner window
    ' to be the active window and then splits that
    ' window into two horizontal windows.
    Dim entry
    For Each entry In ThisDrawing.Viewports
        If entry.name = "TESTVIEWPORT" Then
            Dim lowerLeft
            lowerLeft = entry.LowerLeftCorner
            If lowerLeft(0) = 0 And lowerLeft(1) = 0 Then
                Set newViewport = entry
                Exit For
            End If
        End If
    Next
    newViewport.Split acViewport2Horizontal
(defun c:Example_ActiveViewport()
    ;; This example returns the current viewport.
    ;; It creates a new viewport and makes it active, and
    ;; Then it splits the viewport into four windows.
    ;; It then takes one of the four windows, and splits that
    ;; window horizontally into half.
    ;; Returns current viewport of active document
    (setq currViewport (vla-get-ActiveViewport doc))
    (alert (strcat "The current viewport is " (vla-get-Name currViewport)))
    ;; Create a new viewport and make it active
    (setq viewports (vla-get-Viewports doc))
    (setq newViewport (vla-Add viewports "TESTVIEWPORT"))
    (vla-put-ActiveViewport doc newViewport)
    (alert (strcat "The new active viewport is " (vla-get-Name newViewport)))
    ;; Split the viewport in four windows
    (vla-Split newViewport acViewport4)
    ;; Make the newly split viewport active
    ;; Note that current drawing layout will show four windows.
    ;; However, only one of the windows will be active.
    ;; The following code sets the lower-left corner window
    ;; to be the active window and then splits that
    ;; window into two horizontal windows.
    (vlax-for each-viewport viewports
        (if (= (vla-get-Name each-viewport) "TESTVIEWPORT")
            (progn
                (setq lowerLeft (vla-get-LowerLeftCorner each-viewport))
                (if (and (= (vlax-safearray-get-element (vlax-variant-value lowerLeft) 0) 0)
                         (= (vlax-safearray-get-element (vlax-variant-value lowerLeft) 1) 0)
                    (setq newViewport each-viewport)
    (vla-Split newViewport acViewport2Horizontal)
GMT+8, 2026-10-28 04:51
