ActiveTextStyle 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 738| 评论: 0|原作者: admin|来自: AutoCAD
指定绘图的活动文本样式。
object.ActiveTextStyle
类别: 文档
此属性应用于的对象。
只读:不
类型:TextStyle
绘图的活动文本样式。
添加到图形中的新文本将采用活动文本样式。未指定不同文本样式的现有文本将采用新的活动文本样式。
仅将当前活动文本样式重置为活动文本样式后,对当前活动文本样式所做的更改才会可见。若要重置活动文本样式,只需使用更新的文本样式对象调用此属性即可。
注意:必须调用该方法才能查看此更改。Regen
若要为对象指定不同的文本样式,使其不会随活动文本样式一起更改,请使用该属性。StyleName
Sub Example_ActiveTextStyle()
    ' This example returns the current text style
    ' and then sets a new style.
    ' Finally, it returns the style to the previous setting.
    Dim newTextStyle As AcadTextStyle
    Dim currTextStyle As AcadTextStyle
    ' Return current text style of active document
    Set currTextStyle = ThisDrawing.ActiveTextStyle
    MsgBox "The current text style is " & currTextStyle.name, vbInformation, "ActiveTextStyle Example"
    ' Create a text style and make it current
    Set newTextStyle = ThisDrawing.TextStyles.Add("TestTextStyle")
    ThisDrawing.ActiveTextStyle = newTextStyle
    MsgBox "The new text style is " & newTextStyle.name, vbInformation, "ActiveTextStyle Example"
    ' Reset the text style to its previous setting
    ThisDrawing.ActiveTextStyle = currTextStyle
    MsgBox "The text style is reset to " & currTextStyle.name, vbInformation, "ActiveTextStyle Example"
(defun c:Example_ActiveTextStyle()
    ;; This example returns the current text style
    ;; and then sets a new style.
    ;; Finally, it returns the style to the previous setting.
    ;; Return current text style of active document
    (setq currTextStyle (vla-get-ActiveTextStyle doc))
    (alert (strcat "The current text style is " (vla-get-Name currTextStyle)))
    ;; Create a text style and make it current
    (setq textStyles (vla-get-TextStyles doc))
    (setq newTextStyle (vla-Add textStyles "TestTextStyle"))
    (vla-put-ActiveTextStyle doc newTextStyle)
    (alert (strcat "The new text style is " (vla-get-Name newTextStyle)))
    ;; Restore the previous text style
    (vla-put-ActiveTextStyle doc currTextStyle)
    (alert (strcat "The text style is restored to " (vla-get-Name currTextStyle)))
GMT+8, 2026-10-27 01:18
