ActiveLayer 属性 (ActiveX)
指定活动图层。 支持的平台:仅限 Windows 言论创建新对象时,将放置在活动图层上。若要更改现有对象所在的图层,请使用该对象的属性。Layer 要创建新图层,请使用以下方法。Add 要更改图层的可见性或其他属性,请参阅对象。Layer 例子VBA: Sub Example_ActiveLayer()
' This example returns the current layer
' and then adds a new layer.
' Finally, it returns the layer to the previous setting.
Dim currLayer As AcadLayer
Dim newLayer As AcadLayer
' Return the current layer of the active document
Set currLayer = ThisDrawing.ActiveLayer
MsgBox "The current layer is " & currLayer.name, vbInformation, "ActiveLayer Example"
' Create a Layer and make it the active layer
Set newLayer = ThisDrawing.Layers.Add("TestLayer")
ThisDrawing.ActiveLayer = newLayer
MsgBox "The new layer is " & newLayer.name, vbInformation, "ActiveLayer Example"
' Reset the layer to its previous setting
ThisDrawing.ActiveLayer = currLayer
MsgBox "The active layer is reset to " & currLayer.name, vbInformation, "ActiveLayer Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ActiveLayer()
;; This example returns the current layer
;; and then adds a new layer.
;; Finally, it returns the layer to the previous setting.
;; Return the current layer of the active document
(setq currLayer (vla-get-ActiveLayer doc))
(alert (strcat "The current layer is " (vla-get-Name currLayer)))
;; Create a Layer and make it the active layer
(setq layers (vla-get-Layers doc))
(setq newLayer (vla-Add layers "TestLayer"))
(alert (strcat "The new layer is " (vla-get-Name newLayer)))
;; Restore the previous layer
(alert (strcat "The active layer is restored to " (vla-get-Name currLayer)))
GMT+8, 2026-10-27 13:08
