ActiveDocument 属性 (ActiveX)
指定活动文档(图形文件)。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_ActiveDocument()
Dim activeDoc As AcadDocument
' Returns current document in AutoCAD
Set activeDoc = ThisDrawing.Application.ActiveDocument
MsgBox "The active document is: " & activeDoc.name, vbInformation, "ActiveDocument Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ActiveDocument()
;; Returns current document in AutoCAD
(setq activeDoc (vla-get-ActiveDocument acadObj))
(alert (strcat "The active document is: " (vla-get-Name activeDoc)))
GMT+8, 2026-10-28 04:53
