Active 属性 (ActiveX)
确定文档是否为会话的活动文档。 支持的平台:仅限 Windows 属性值只读:是的 类型:布尔 确定文档是否为会话的活动文档。
言论没有其他评论。 例子VBA: Sub Example_Active()
' This example creates two new drawings and determines
' which of the drawings is the active drawing.
Dim NewDrawing1 As AcadDocument
Dim Newdrawing2 As AcadDocument
Set NewDrawing1 = ThisDrawing.Application.Documents.Add("")
Set Newdrawing2 = ThisDrawing.Application.Documents.Add("")
Dim activeStatus As String
Dim drawing As AcadDocument
activeStatus = ""
For Each drawing In ThisDrawing.Application.Documents
If drawing.Active Then
activeStatus = activeStatus & drawing.Name & " is active." & vbCrLf
Else
activeStatus = activeStatus & drawing.Name & " is not active." & vbCrLf
End If
Next drawing
MsgBox activeStatus
可视化 LISP: (vl-load-com)
(defun c:Example_Active()
;; This example creates two new drawings and determines
;; which open drawing is the active drawing.
(setq docs (vla-get-Documents acadObj))
(setq NewDrawing1 (vla-Add docs ""))
(setq NewDrawing2 (vla-Add docs ""))
(setq activeStatus "")
(vlax-for each-doc docs
(princ (vla-get-Active each-doc))
(if (= (vla-get-Active each-doc) :vlax-true)
(setq activeStatus (strcat activeStatus (vla-get-name each-doc) " is active.\n"))
(setq activeStatus (strcat activeStatus (vla-get-name each-doc) " is not active.\n"))
(alert activeStatus)
GMT+8, 2026-10-28 09:48
