您可以通过首先创建对象的实例,然后将其添加到表示“模型”或“图纸空间”的块表记录中来创建多行文本对象。对象构造函数不采用任何参数。创建对象的实例后,可以使用其属性为其分配文本字符串、插入点和宽度以及其他值。可以更改的其他属性会影响对象的文本高度、对齐方式、旋转角度和文本样式,或将字符格式应用于所选字符MTextMTextMText 创建多行文本对象以下示例在“模型”空间的坐标 (2, 2, 0) 处创建一个对象。MText VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CreateMText")> _
Public Sub CreateMText()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a multiline text object
Using acMText As MText = New MText()
acMText.Location = New Point3d(2, 2, 0)
acMText.Width = 4
acMText.Contents = "This is a text string for the MText object."
acBlkTblRec.AppendEntity(acMText)
acTrans.AddNewlyCreatedDBObject(acMText, True)
End Using
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("CreateMText")]
public static void CreateMText()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a multiline text object
using (MText acMText = new MText())
acMText.Location = new Point3d(2, 2, 0);
acMText.Width = 4;
acMText.Contents = "This is a text string for the MText object.";
acBlkTblRec.AppendEntity(acMText);
acTrans.AddNewlyCreatedDBObject(acMText, true);
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub CreateMText()
Dim mtextObj As AcadMText
Dim insertPoint(0 To 2) As Double
Dim width As Double
Dim textString As String
insertPoint(0) = 2
insertPoint(1) = 2
insertPoint(2) = 0
width = 4
textString = "This is a text string for the mtext object."
' Create a text Object in model space
Set mtextObj = ThisDrawing.ModelSpace. _
AddMText(insertPoint, width, textString)
ZoomAll
相关概念父主题: |
GMT+8, 2026-11-21 18:36
