UnloadARX 方法 (ActiveX)
卸载指定的 AutoCAD ARX 应用程序。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论如果调用此方法时指定的应用程序被锁定,则该方法将失败。 注意:不要尝试卸载文件 acvba.arx。
例子VBA: Sub Example_UnLoadARX()
' This example unloads an ObjectARX application from the AutoCAD session.
' Note: The application listed here does not exist and
' will cause an error when run. Change the application name
' to the name of your ObjectARX application.
On Error GoTo ERRORHANDLER
ThisDrawing.Application.UnloadArx "MyARXApp.arx"
ERRORHANDLER:
MsgBox Err.Description, , "UnloadARX"
可视化 LISP: (vl-load-com)
(defun c:Example_UnloadARX()
;; This example unloads an ObjectARX application from the AutoCAD session.
;; Note: The application listed here does not exist and
;; will cause an error when run. Change the application name
;; to the name of your ObjectARX application.
(vla-UnloadArx acadObj "MyARXApp.arx")
GMT+8, 2026-10-28 05:59
