Split 方法 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 928| 评论: 0|原作者: admin|来自: AutoCAD
Split 方法 (ActiveX)
将视口拆分为给定的视图数。
object.Split NumWins
类型:视口
此方法应用到的对象。
NumWins的
访问:仅输入
类型:枚举AcViewportSplitType
  • acViewport2Horizontal
  • acViewport2Vertical
  • acViewport3Above
  • acViewport3Below
  • acViewport3Horizontal
  • acViewport3Left
  • acViewport3Right
  • acViewport3Vertical
  • acViewport4
返回值 (RetVal)
无返回值。
尽管已调用该方法,但在使用该属性使视区处于活动状态之前,不会显示更改。即使视口在调用 之前处于活动状态,这也是必需的。SplitActiveViewportSplit
视口不必处于活动状态即可使此方法正常工作,但是,必须将其重置为活动状态才能查看此方法的结果。
Sub Example_Split()
    ' This example creates a new viewport and makes it active.
    ' Then it splits the viewport into four windows.
    ' It then takes one of the four windows, and splits that
    ' window horizontally in half.
    Dim newViewport As AcadViewport
    ' Create a new viewport and make it active
    Set newViewport = ThisDrawing.Viewports.Add("TESTVIEWPORT")
    ThisDrawing.ActiveViewport = newViewport
    ' Split the viewport in four windows
    newViewport.Split acViewport4
    ' Make the newly split viewport active
    ' Note that current drawing layout will show four windows.
    ' However, only one of the windows will be active.
    ' The following code sets the lower-left corner window
    ' to be the active window and then splits that
    ' window into two horizontal windows.
    Dim entry
    For Each entry In ThisDrawing.Viewports
        If entry.name = "TESTVIEWPORT" Then
            Dim lowerLeft
            lowerLeft = entry.LowerLeftCorner
            If lowerLeft(0) = 0 And lowerLeft(1) = 0 Then
                Set newViewport = entry
                Exit For
            End If
        End If
    Next
    newViewport.Split acViewport2Horizontal
(defun c:Example_Split()
    ;; This example creates a new viewport and makes it active.
    ;; Then it splits the viewport into four windows.
    ;; It then takes one of the four windows, and splits that
    ;; window horizontally in half.
    ;; Create a new viewport and make it active
    (setq newViewport (vla-Add (vla-get-Viewports doc) "TESTVIEWPORT"))
    (vla-put-ActiveViewport doc newViewport)
    ;; Split the viewport in four windows
    (vla-Split newViewport acViewport4)
    ;; Make the newly split viewport active
    ;; Note that current drawing layout will show four windows.
    ;; However, only one of the windows will be active.
    ;; The following code sets the lower-left corner window
    ;; to be the active window and then splits that
    ;; window into two horizontal windows.
    (vlax-for entry (vla-get-Viewports doc)
        (if (= (vla-get-Name entry) "TESTVIEWPORT")
            (progn
                (setq lowerLeft (vlax-variant-value (vla-get-LowerLeftCorner entry)))
                (if (and (= (vlax-safearray-get-element lowerLeft 0) 0)
                         (= (vlax-safearray-get-element lowerLeft 1) 0))
                    (setq newViewport entry)
    (vla-Split newViewport acViewport2Horizontal)
GMT+8, 2026-10-28 04:51
